The intercooler is in the inlet manifold.@DaveB but won’t those mounting locations obstruct airflow? Especially the ST4-4 which will basically cover the inter cooler areas?
Depends on your needs, for me it’s partly about the types of lights and partly where they are mounted. I’m partial to roof-mounted wide/spot lighting as I reckon it offers a better view of the road shoulder (where Skippy leaps out from) and it has less tendency to flare off dust/fog than if the same lights are mounted lower. That’s all a function of country/unsealed roads though so it’s not like I’d need it in Sydney.Should it still then be necessary to add additional lights to the IG?
Yep, sounds sensible. I’m aiming to go top tube of the roo bar and if that’s insufficient then fab up a gutter mount in front of the safari windows. Did you have any ideas on the 3/4 rack, or were you thinking something else?I don’t want the lightbar on the roof which is where the OEM option is mounted. I have had bad experiences with bonnet and windscreen glare, I have also specked the safari windows and don’t want light coming in there, and also for that reason don’t want the full length roof rack which would mean a crossbar right at the front of the roof to mount the bar to and that would look silly and also mess with the Safari windows. I have specced the roo bar though and Inwill mount a 20” lightbar under the bottom bar of the roo bar though if it fits.
I hope they work with the high beam, legal requirement in Australia, but are separately switched from the overhead panel. So they come on with high beam only when you select them.Good day. My question is on the Auxiliary High Beam lights fitted on the inside of the main lights. What is the strength and is it linked to work with the vehicle's high and dim mode?
"The #Grenadier is fitted with powerful LED lights at each end – plus a set of Auxiliary High Beam lights fitted as standard" on the SA Facebook page. Should it still then be necessary to add additional lights to the IG?
I am hoping this light bar will fit suspended from the top of the roo bar 682mm wide 24 leds and 18,000 lumensI don’t want the lightbar on the roof which is where the OEM option is mounted. I have had bad experiences with bonnet and windscreen glare, I have also specked the safari windows and don’t want light coming in there, and also for that reason don’t want the full length roof rack which would mean a crossbar right at the front of the roof to mount the bar to and that would look silly and also mess with the Safari windows. I have specced the roo bar though and Inwill mount a 20” lightbar under the bottom bar of the roo bar though if it fits.
That one is good, also like this one. I might donunder the top bar, but I reckon it will look neater under the bottom bar https://www.stedi.com.au/st3301-pro-24-5-inch-16-led-light-bar.htmlI am hoping this light bar will fit suspended from the top of the roo bar 682mm wide 24 leds and 18,000 lumens
Linear-24 Elite
<p>Combination of highly efficient 3W ‘premium bin’ LEDs</p> <p>Dual-output mode allows the light to be operated at a lower UNECE E-mark reference - (requires <a href="/linear-e-mark-cap-replacement-part.html">Linear E-Mark Cap</a> – sold separately)</p> <p>5000K LED colour temperature and 80CRI...www.lazerlamps.com.au
