Let's get some perspective: Is your Grenadier AC working as it should?
G-Man
12:57 PM
Aberdeen, Scotland
Who else's AC is batsh1t crazy and randomly blows hot air one day and cold the next on the exact same setting? I don't think the AC system got the attention it deserved during the 1.2 million miles of road testing, that's for sure. I love my new truck but it's the one thing that drives me nuts on pretty much a daily basis as I fiddle away at the controls and I'm surprised Ineos haven't found a fix for it yet. I gather it's down to sticky solenoid valves or such like and is probably an expensive warranty concern for them.
It would be useful to set up a poll on this forum and get an idea of what percentage and numbers of owners here have flaky AC. This forum must represent a decent amount of the Grenadier owner population, perhaps it would help sharpen Ineos' perspective on the issue if it popped up on every Google search relating to Grenadier AC issues. I don't have the ability to raise a forum poll but maybe @Stu_Barnes would consider it a worthy exercise
It’s super frustrating because I think the HVAC is erroring-out in flame mode, but is just the whacky sensor(s). I will only have access to cooling at the extreme end of the dial, anything less produces heat. Driving for a while usually gives a few more AC clicks, but shouldn’t this be based on driver demand not vehicle limitations?
Particularly on the East Coast, there are time you don’t open your windows due to pollen.
Upvote 0
Mine works fine (5/24 build date). I have never had any of the issues some have complained about. I put it in auto... set the temp and don't touch it.
Upvote 0
For AC, I mainly just set mine to max low and use the fan speed to modulate temperature. It seems to come with the extra benefits of stopping the start/stop from triggering. This may not work in cooler climates though.
Upvote 0
Same here. I never have start/stop activate, unless it is winter and my a/c is off.
Upvote 0
Finally got the A/C bug where the system wouldn't turn off and blowing flaming hot air. Was on a road trip and the thought of a few days of this was not pleasant, but this forum is a valuable resource. Turn if off, lock the doors, let it sit for 5-10 minutes (I guess 5 minutes, 30 seconds is the key) and all back to normal. I normally run in auto and haven't had a problem since I purchased in February.
Upvote 0
Just to follow up on this: I tentatively think I've fixed it. For me, the solution was:
1. check coolant levels. both of my reservoirs were a little low, so I filled them to the max fill line. This did not (on it's own) fix the problem.
2. Do the "service mode" trick. This is described elsewhere on the forums, though I'm having trouble finding a link. Basically it was open the bonnet, depress both the gas and brake for 10 seconds, then start the ignition. At this point "service mode" shows up on the computer screen, though it took a number of tries. Once I got service mode running, I let the car sit for 15 minutes or so, and eventually got a message like "service mode complete"
After BOTH of those processes, my AC has been working 100% of the time for a few weeks, both on auto mode and on manual mode. Hopefully this helps everyone else who's having the issue!
Upvote 0
I have a start up sequence that seems to work until it doesn't. I'm not sure what the final fix is or if Ineos even has one. I took mine in to Ineos with this complaint and they sad it was a leak in the AC system and needed a hose replaced and also they bled the system. It worked fine for a few days then the same issue came back again. Took it back to the dealer and they couldn't replicate it so there was "no problem to fix". I think it has something to do with vent baffles that get a wrong code sent to the computer at start up. If I am meticulous about my start up sequence I can go months without a problem but it seems if I forget one step it goes bad again.
Like I said, the AC is great until it isn't.
Upvote 0
Just as an observation. I live in the North of Scotland, around 58°N and it’s pretty rare that it gets “hot”. Yesterday it was 30C (86F) and humid as hell. Grenadier was ice cold inside. Actually too cold.
I’m calling that a win. It’s very good at very cold and it’s very good at very hot. Settling on a perfect temperature anywhere in between can be a bit hit and miss but it’s a million times better than an old Defender. 😉
Upvote 0
Mine was ok for awhile after a number of times bleeding the system. It had now gone back to it's old ways of only hot or cold, in-between settings.can be cold upfront and hot in the rear but generally if not on full heat it's cold, just not AC cold until on max cold.
I have topped up both reservoirs as required but noticed they are both leaking on the joints/seams. Pointed out to dealer and one has been changed but the other is on back order. Hopefully get it fixed one day and have a heating system that sort of works 🤞
Upvote 0
After months of working correctly. Done everything to it, dismantled the dash, insulated some of the pipes, resealed the foot vents. Again, it sometimes gets stuck on hot. When it’s stuck on hot, the pipe underneath the glove box is absolutely roasting.
Sometimes it drips on the mats especially in the recent humid weather and I start the car every-time, waiting for dash lights to go out. I now think it’s a software issue and the actuators which diverts hot and cold.
I never known any other car which can get so hot or so cold very quickly.
Upvote 0
Mine is an early model, is yours?
Have you noticed that the dials on newer versions click more decisively on each segment? I'm beginning to wonder if it's a problem with the controls?
Upvote 0
May 2023. The feel of the dials I can say are loose, tactile feedback isn’t a strong point. Not noticed on newer models but I hear newer models also have this issue.
Maybe, but personally I think it’s the software. I try to leave it on auto 23 degrees and not touch it. One day, it could be good and one day not, depending on the weather or whether it’s on this period. 😂
Reactions: CRH
Upvote 0
So, I’m not going to read all 6,000 pages of this thread… I just wanted to say that I have had NO issues at all with my MY24 base grenny AC or heat functions. Everything has worked as expected since I brought her home last November. My salesman admitted it can be finicky, but highly advised to never use the AUTO function when it came to Heat or AC. He said he felt that’s where most issues came from. I didn’t question him but took his advice and have never used the AUTO function. I will occasionally hear a whistle or a whine while running the AC or heat, but with the radio volume up, it’s not noticeable.
Upvote 0
But the problem is if you turn on Auto, you may have HVAC issues if you’re unlucky.
Also, It defeats the purpose of having Auto if you can’t use it.
Reactions: CRH
Upvote 0
I wish it would get colder faster, but euro cars all seem to lack the US car “Chicago slaughterhouse meat freezer” setting. Other than that I won’t comment, because commenting that my AC works in thread about non working AC is kinda stupid. It’s like joining an emphysema forum to talk about my freediving trip in the Bahamas.
Upvote 0
Or, it defeats the purpose of having cold/hot air if I do use it. But I get your point.
To be fair, there other features (buttons) in the grenny (and other vehicles for that matter) that I don’t use or hardly ever use. The recirculating air feature is an example.
Upvote 0
Just chiming in to say my Grenny takes about 7 hours to pump out some lukewarm air. In summer, the cold air coming out is OK’ish but not super cold either.
Based on this thread it seems like there’s not really any solution.. other than to accept that the HVAC system in the Grenadier is just crap?
Upvote 0
Maybe somebody should organize a day to drive their cars to the Grenadier pub and put signs on them about the HVAC. Who knows, maybe Jr would be there and give you guys all new trucks (or 50k of credit) TIC
Upvote 0
First step is to check coolant levels, top up both coolant tanks to max on a cold engine. This usually fixes it. It should then blow hot air within 5 mins of turning the car on.
If this doesn’t work, it needs a bleed, you can get the dealer to do it.
It sounds simple, but not all dealers are quite as switched on as others due to lack of training from Ineos.
The HVAC isn’t great we all know that but it is the quickest car I’ve owned to get really really hot or freezing cold. Sometimes, the actuators get stuck on, which is a software problem and which also causes the condensation drips on the passenger mat.
Reactions: CRH
Upvote 0
Don't lose hope @HugoB. I previously worked with some public servants that spent 7 hours and 36 minutes each day pumping out lukewarm air so your situation could be worse.
I think there are a number of owners that have had success after cooling system bleeding and an A/C gas leak check and recharge. This is for an improvement in temperature not regulation control - different problem.
Upvote 0
