Leisure Battery Install
the only charging port that appears future proof is the cigarette lighter style. usb's will change yet again, and everything on the planet has an adapter for the ol' cigarette port. I just use those.
Reactions: CRH
That's true indeed. The future proofing is more intended for the fuse and power design. I've allowed for expansion on my behalf too, the wiring and fuse set up allows for a significant amount of consumers to be added without needing to swap for larger amperage cables etc. The USB C etc are easily replaced with 12v sockets within a few minutes if necessary.
Very much appreciated.
Yes, the button is a very nice little touch from Titan. But, again, customer specified for a mechanical switch mounted in plain sight.
Did you mount the button? I noticed there is no securing tabs or back nut to locate it neatly onto a panel.
You have to unscrew it really carefully. The top ring around the button needs holding and turning. I got mine off with a couple of scratches.
The biggest issue was that the switch mechanism inside is incredibly fragile, it's like a reed switch in there. Slip a two large washers over the button thread and reinstall as a surface mount.
Also Titan do sell one which is easier to surface mount, but is made for parallel batteries. I called them up about taking the switch to pieces and they said they had something which would surface mount better, but I wanted to try my way.
Thank you!
I may enquire as I have some installs booked in, a neater way to fit this switch is certainly needed. If I find anything out, I shall surely let you know. How did you find the install? Was it for your own vehicle, if so, how do you find the systems day to day useability?
Thank you!
It's my vehicle and I found it relatively easy. In all honesty, I'm waiting on the aux battery holder to arrive from the dealer, so it's all held in there temporarily until that arrives and I can reinstall it properly.
I originally went for a Renogy DCDC charger, (which for anyone reading this) DO NOT use. The Renogy ignition sensing was unreliable and had a cooling down period where it would only stop charging the aux when the starter dropped to 11.4v. I even bought the Bluetooth adapter to make sure there wasn't a setting in there. It would keep charging the aux at 500w and I ended up with a starter battery at <50%, which isn't ideal.
Victron was a dream. Voltage sensing rather than ignition sensing allows for greater control. I would suggest plugging your Victron settings into ChatGPT and optimising them, as they are slightly off and you will find your Titan showing a lot of cell overvoltage protections. Whilst not a bad thing, you really don't want it always being in a protection mode. Further to this, if you don't want to leave the Titan at 100% you can change the values to slightly under charge the battery to 95% to help with longevity. Again, Chat will help you with these settings and appears to know the Victron and Titan systems - just screenshot the settings pages and tell it your install and you'll get the correct values. (example, the default absorption for Lipo by Victron is 2 hours. This should be 30 mins).
I also spoke to Titan about any settings to stop charging at 95% and they said it was one of their most common questions, but sadly not something they are able to implement.
My install purpose was for an inverter, so went with a Renogy 1000w with external control and two gang sockets where you've installed your voltmeter. Plan is to power some low voltage stuff from the aux. I bought the OEM second row overhead switch panel and exterior grab handle power out boxes, so I'll use that for those. (Bought my car S/H, so had to make do with what I got!)
I am tempted to install a second DCDC to return power back to the starter battery from the aux when the car is off, as it drives me insane that the car, for emissions purposes, won't charge the starter beyond 80%, so I'll just override that with another DCDC.
In terms of day to day, it's fantastic now. Was running it yesterday on a job and everything charging and working nicely.
I was tempted to use the factory battery bracket, but opted to make stainless steel ones instead for a little extra flair at no extra cost.
I very much appreciate the guidance regarding the Victron, I will certainly be looking into adjusting the settings as you have mentioned.
I'm glad you had a chance to test out the Renogy, I was keen to experiment with one regarding solar input too. I may end up trying out the Redarc BCDC1240 instead.
You seem incredibly competent with the workings of the systems and the Grenadier, I can only imagine the set-up you create will reflect that.
Ha.. Ha.. Ha.....
"Competent" might be the wrong word. My temporary fix until the battery bracket arrives is a 1m aluminium ruler, bent into the right shape and bolted down. The bonus is that I can use it to check the width of the battery at a glance.
I had @IneosGreadierTech install his battery system the other week. Since then I purchased a Dometic compressor fridge CFF12 and left it running on the drive for about 36 hours and it only used about 5% of the battery. Couple of 12v 20 amp sockets in the little cubby hole to the jack, also spare ports?, under the seat so I can easily add extras.
Had to add an extra 12v socket under there as the Dometic cable was too short.
If you want to know any more, or get some pictures, please ask @IneosGrenadierTech as I am incompetent, also took no pictures, which he did when installing. I didn't have the exterior off switch or battery indicator as there is a switch on the battery and it links to your phone for info.
All done very quickly and neatly, really been pleased with it and been using regularly
So, this one ended up with the full works.
Ready to run 400w Solar panels using the MPPT100/30 with 6mm2 PV Cabling to an Anderson PP75 mounted next to the roof plugs.
I've also removed the auxiliary fuseboard power and placed it onto the leisure system and fused it, now allowing the light pods and roof tent to be powered via the leisure system. Added some hidden 12v ports in the bottle jack enclosure. This system is fully hidden from view in all aspects. Very pleased with how it turned out
Reactions: CRH
Fantastic install. What mount did you use for the victron DCDC? I couldn't find one, so it's screwed on a board wedged between metal edges. Also, would love a product number for the littelfuse box.
Thank you!
I actually custom make a little bracket for them and use rubber mountings to raise it up enough to clear the handbrake cables. The MPPT is mounted on extended bolts and use rubber feet to stop vibrations etc.
The Fusebox comes from 12v Planet, part no. 1310839. It's great as it has a negative bus bar so once installed, it allows my customers to easily add more circuits
Thank you!
I’ve installed the same fuse box in my battery compartment and use 12v planet for most of my projects. They are very good and have a WhatsApp helpline for any technical questions
I'm very happy with them, they seem to have everything I need. If I'm stuck, there's a local electronic supplier a stones throw away too which certainly helps
