Leaning to the Left
RB60
6:03 AM
Chicago
Walking up to my 25 Fieldmaster, I looked like it leans toward the drivers side. Thought maybe it was a parking lot angle.
Got it home and in the garage. Measured from the floor to the bottom of the outer fender opening. Centered with the front wheel.
Yep, it's off about 1/2 inch. Seems like that should be no big deal but its noticeable.
Weak spring? Knowing me, this will bug me. Not sure the dealer will want to do anything but I'll ask.
Any suggestions? Wonder if I could add a spacer?
The fuel tank is on the right. Fill it up and measure again. That I’ll put 145 pounds on the right side. If it’s still way off then take it to the dealer
That's a known issue with some of them. Don't add a spacer. Take it to the dealer. Show them the measurements. They have a Technical Service Bulletin for it and will replace the springs under warranty to fix the lean.
Are you sure about that?
I'm afraid @rob88 is not a Grenadier owner and judging by some of his comments in various threads clearly hasn't even read the Grenadier's owners manual. He has come " clean" about his status in a recent thread, but please be cautious over any comments he may make.
I'm afraid @rob88 is not a Grenadier owner and judging by some of his comments in various threads clearly hasn't even read the Grenadier's owners manual. He has come " clean" about his status in a recent thread, but please be cautious over any comments he may make.is of no use on the forum in my view. Mostly posting misleading nonsense that confuses owners and prospective owners.
This rob88 is of no use on the forum. Mostly posting misleading nonsense. @Krabby and @Stu_Barnes If you have time. Please go through the posts of this member. I’ve called them out several times and they still post misleading nonsense.
