Introduced here:
https://www.theineosforum.com/threa...your-grenadier-today.12411127/post-1333369436
2024 ( Petrol ) Ineos Trialmaster with ( OEM ) RED integrated winch
We’ve added the following components over the last year - Most of which occurred over the last few weeks:
Alu-Cab Silenus RTT - Replaced the roof grab rails with black ones from GrenadierUSA and upgraded the struts.
Make sure you request the “heavier load” ( 500N or 800N ) struts if you’re going to put load bars, solar panels etc.
on the RTT…
We’ve also coated the top of the rear bumper with 3M Safety Walk as an anti-slip coating for rear cargo area entry
and exit.
Alu-Cab Shower Cube
Alu-Cab 270 Shadow Awning with Alu-Cab awning gutter
Alu-Cab Molle Panels for Joolca ( HOTTAP pumped hot / cold ) water system and
Propex ( PS2000 Portable ) heater on driver’s side with VAAST 18L water tank on passenger side.
We used Integral’s Molle mounts for mounting the HOTTAP pump and quick release mount to the Alu-Cab
Molle Panels.
HOTTAP modifications:
We’ve hacked the HOTTAP to expose a 60C ( 140F ) cutoff - Joolca actually supporting this modification [5]
is one of the reasons why we went with this system. It’s highly recommended. We also added the top vent directional
cover from 813 Fabrications since we want to run the HOTTAP on the Molle Panel when convenient. The HOTTAP pump
bracket is also from 813 Fabrication.
ROAMRest custom mattress for the Silenus RTT - HEST stuff for bedding since they’re close to us.
300W Solar Array - 6 x 50W Sunflare XPLOR BLOX panels.
Buzz Overland Big Brake Kit ( red of course ) along with Buzz door steps.
REDARC BCDC ALPHA50 12V 50A DC Battery Charger
REDARC ALPHA150 12V 150AH Lithium ( Auxiliary ) Battery
LRA ( Brown Davis ) Auxiliary Fuel Tank - We’re coating the tank with a 3M rubberized undercoat before
installation. We ordered ours with the upgraded fuel transfer pump and this appears [7] to be a Carter P4070.
Braid Fullrace T Dakar Wheels with ( Agile Offroad ) Apex RPV + TPMS brackets
Victron Orion-Tr 12V / 24V 5A Isolated DC DC Converter - Used for Starlink Mini via external mini-Anderson.
LETECH Multi-Function rear ladder - We’ve put another 18L LIFESAVER Jerry for water in this location.
Ineos ( OEM ) Roo Bar
Ineos ( OEM ) Driver’s side grab handle
Wolfbox G900Pro rear view mirror with 67Designs mount since the rear is packed with gear.
Ineos ( OEM ) front and rear “black” springs - We’re thankful to the forum experts for documenting the
relevant model numbers since we didn’t have access to the Ineos tech portal when we ordered them.
Nimbus Erebus oleo-pneumatic dampers - Current ETA for this product is targeting the third week of April.
Bilstein BE5 A580IG Steering Damper.
GrenadierUSA machined center console ( looks cool ) and cargo wall L-tracks.
GP Factor folding tailgate table and Starlink Mini mount - Powered through external mini-Anderson
port on the driver’s side ( see below ).
Agile Offroad’s ARB Onboard ( brushed single compressor ) Air Kit - stashed under the rear bench seat
and plumbed into the rear cargo area on the passenger side.
Abenteuer 4x4 Rock Sliders - Wanted to minimize any loss of ground clearance or change in ramp angle.
REDARC Tow-Pro EBC - Mounted under rear bench seat with dial adjustment in center console ( in front of e-brake ).
Guzzle H20 ( Stream ) water purifier - We typically draw from local ( non-potable ) sources in our region so JIT
filtration / purification is a great idea for us.
GrenX Aluminum Snorkel System with Sealed Airbox ( OEM styled variant ) - Decided on a Volant Donaldson
PowerCoreG2 ( pod ) air filter [2] since we’re planning on a fair bit of desert travel next year. We’ve ordered a
UNIFILTER oiled pre-filter ( PRECLEAN 67/3 ) for the snorkel [3]. See [6] for images of the pre-filter.
See [8] for a brief discussion ( including images ) of the default filter shipping with the GrenX petrol sealed
airbox.
Other bits:
Rosen visors and SUMA ( convex ) mirrors from Owl - Wanted these for the Molle panels.
Black Sheep Innovations display sun visor for the head unit - Seems to minimize the glare a bit.
Owl CNC machined replacement rear door and bonnet handles ( red of course ).
Agile Offroad ( Baja Designs ) offroad grill lights - AUX1 with dimmer support at the moment.
We wanted to leverage the existing Auxiliary ( offroad ) lighting switch since it no longer serves any purpose…
Baja Designs ( passenger / driver ) scene lights ( 2 x S2 Sport ) - Switched externally since these
are powered through roof mounted DTPs - @Loc Nar’s post [1] was inspiration for that feature.
The remaining roof mounted DTP ports ( sans lighting ) are used as needed for the HOTTAP pump and igniter,
Propex igniter, and charging the Guzzle H2O Stream purifier.
Baja Designs reverse lights ( 2 x S2 Sport - attached via Leitner Designs chase light brackets )
GME GMRS ( compact ) radio with KAON LHS ( driver side ) antenna mount - We’ve gone with the XRS
Connect Outback Pack for our GMRS radio system.
Clear ClimAir Wind Deflectors for the front and rear passenger and driver side windows.
Forgot to mention:
Goose Gear CampKitchen and rear plate system ( driver side ) - We’re running a National Luna Legacy Smart 50L
fridge / freezer and Cook Partner 22” ( 2 burner ) stove within the CampKitchen module.
A few bits from the Grenadier Works store too ( the interior rear door handle is awesome ) - Console mounting bracket for
a 67Designs tablet mount, license plate light shrouds, map light glare shields, interior rear door handle, and L-track accessory
nuts.
MaxTrax setup for Silenus [4]:
One Alu-Cab load bar ( 1450 mm length ) with low profile ( flat ) mounts.
KAON stealth flush folding Maxtrax & TRED mounts to suit platform racks.
KAON Maxtrax mounting pin set - 17mm thread.
I hope KAON sends me stickers this time
No doubt other stuff I’ve failed to mention…
[1] https://www.theineosforum.com/threads/work-light-on-roof-grab-bar.12415826/post-1333313533
[2] https://www.theineosforum.com/threa...your-grenadier-today.12411127/post-1333369583
[3] https://www.theineosforum.com/threa...ls-for-the-ig-and-qm.12420533/post-1333370926
[4] https://www.theineosforum.com/threads/maxtrax-mounted-on-silenus-roof.12419353/post-1333370105
[5] https://support.joolca.com/hc/en-us/articles/10020381403023-Replacing-Temperature-Sensor-Guide
[6] https://www.theineosforum.com/threa...ls-for-the-ig-and-qm.12420533/post-1333370926
[7] https://www.theineosforum.com/threads/brown-davis-or-long-range-automotive.12417306/post-1333372236
[8] https://www.theineosforum.com/threa...your-grenadier-today.12411127/post-1333370076
on the RTT…
and exit.
Alu-Cab Shower Cube
Molle Panels.
airbox.
Other bits:
Forgot to mention:
nuts.
