Isolating a Roof Plug
AFdude412
8:51 PM
Colorado, USA
Has anyone been able to isolate one of the 3 roof line plugs that are on the Ext 3 circuit? I’m looking to power extra lights or a starlink mini that I’d rather keep separate from my scene lights and not route have to run more wires though the roofline.
My only guess is wiring in something like a Garmin power switch from where the EXT 3 roof plugs are sourced, but not sure if I’m this chasing potential use case down correctly.
Any ideas?
Interetesed in isolating the EXT 3 plugs as well. All I can add is that removing the grab handle panel allows limited access to to an internal Deutch connector, in the harness to the external connector. You could run a new supply wire without having to create a new roof penetration (re-purposing the external Deutsch).
I added external waterproof inline switches to the 2 rear roof outlets - effectively gives me 2 circuits that I can operate separately or together (all current warning & camp lights are under the 10A limit should I ever need them at the same time).
I usually have the rear warning light switch set on & the camp lights off so I can activate the warning lights if needed from the overhead switch.
I still have the front outlet available for ???? !
  • IMG_2865.mov
    23.8 MB
Awesome! Got a link?
The ones I got were “yak-power” brand on amazon, but looks Ike they are currently unavailable :
Yak-Power YP-ILS16 Waterproof Inline 12-Volt Power Switch
I searched for others using “inline waterproof switch 12v”
I just cut off the SAE connectors & used heat shrink solder butt connectors to the lights & dip connector to the truck. Note - the led light in the switch is either on when powered or on all the time, depending which direction you wire it. (Mine only glow when powered)
I copied @Loc Nar’s setup to create two external switches for my Baja Designs S2 Sport side lights. See the following post for more information.
Switch for reference:
