Installed 4 wire trailer harness on truck
Are you asking if someone has installed a 4 wire trailer harness?
I'm assuming you did not get the factory hitch option?
The easiest (only?) way of doing this would be to get to the back of the taillights and piggyback off of those wires to trigger your 4 wire harness (assuming you've purchased a kit that just needs the triggers for each output). On the taillight the wire functions are labelled, so it should be pretty easy to see which wires you'll need
Installed CARROFIX Non-Powered Taillight Converter with 20" Inches Leads and 60" Inches 4-Wire Flat Extension Vehicle End Connector from Amazon. Remove Right rear trim panel. 6 bolts and trim clips. Wire harness is easy to get to.
Oh that's interesting... You don't have the TRM but you have the harness going to it; that makes it much more convenient.
What is the build date of your vehicle? (or the last 5 of your VIN)
Installed the 4 pin self closing cover down by hitch. Ran wires through thruhole in floor next to wire harness. 2 rubber grommets. One inside and one under car. Super easy.
Hi, meant to say couldnt find this. My car didnt come with trailer kit. Ive done this before on other trucks. My last five vin is. 41604 thx much
I gave this guy a shot. Though I tapped into the same wires up at the Towing Module plug. There was a little confusion on colors, but the color coding posted above was largely correct minus to primary colors being swapped with their stripe colors. I believe it’s the RT and Tail that you will want to flip the colors. Otherwise this method works. That said, if you have a trailer with lots of lights this unpowered setup might not work well. I plugged in my Nautiques trailer and it immediately threw codes in the Grenadier. But my Nautiques trailer has some fancy LEDs with some logic that the Grenadier does not appreciate. I assume it’s too much load. So I will likely move on to a powered converter and see what that does.
But I can confirm the trigger wires and the functionality with a smaller load trailer light system.
Additionally, there is a round grommet way in the back corner that exits the cab cleanly. The oval grommet just below the trailer wiring harness does not exit the truck.
ZCI Circuit Protected Vehicle Wiring Harness w/ 4pole flat Trailer Connector and installation kit from etrailer.com Product number 119250 KIT. Works perfect
How did you wire it in?
View attachment 7877638View attachment 7877639View attachment 7877640
So I wired it in with the only exception being the purple/red was actually purple/orange. I then plugged it in to one of those magnetic trailer lights kits you get to tow a car…. It immediately threw a code and nothing worked right. Did you mean in your note that the colors were in the wrong order or the wires needed to be switched?
A few photos of my install.... Price? less than $400
First, I would like to point out, with any new car or truck, always use a powered converter module (isolation module).
The modern cars and trucks of today have CAN bus systems, and the tiny wires are not designed to carry any extra load on the light circuits. Also trailer you intend to pull may have old-school incandescent bulbs that draw lots of power. And if you pull a boat, the lights are easily shorted to DC - (ground),
Converter---
Hitch---
I have not had time to tie in the DC+ to power the module and test the output, but thus far, no codes!
My wiring where in tied in upstream of the trailer module (if the above post is correct)
Right turn -Green / brown stripe (correct!)
Left Turn -Yellow / Gray stripe (correct!)
Brake - Blue / orange stripe (purple/red and purple / orange had no signal on my 2024 wagon)
Tail - Green / purple (correct!)
How to remove the right side panel.... I did not have to remove the nut inside the box...
Video link removal of right panel
How the panel installs into the truck
Video link right panel clips
Video link more details of how the side panel clips it...
Here I used posi-tap... Throw those blue things in the garbage!
Here, I used a piece of plastic tubing (like fish tape)to run the wire through the inner wall grommet hole.
Here you can see the plastic hose...
Here you can see the wire taped to be pulled into the truck (I had the cut the trailer wire to get it through the hole)
Here you can see the wires pulled through the rubber grommet.
Now the converter isolation module is inside the truck (right under the cover) along with the splice connections. If it ever fails, it will be much easier to swap out!
(no pic) sorry)
Someone please prove me wrong.... There is no need to get a "brake" signal. (The blinker and the brake are the same light!) If you do connect the RED brake signal to the magic box, your brake light output will not work (turn on the left and right blinkers on your trailer).
