Infotainment LED Screen
mpayton01
5:51 PM
Scottsdale, AZ
Just bought a station wagon. Grenadier Infotainment screen glitchy, for $80k would expect more. Is there an update that corrects this problem. Also when devices connect to hotspot, other audio functions not supported
Any help here is appreciated.
You have to get used to it.. like everything Gren, it takes time to warm to its character.. try using the screen in sunny conditions wearing polarised sunglasses…. You have to use “the force” to see in to its soul….
Residual or tracers of number changes on speedometer, then apps in CarPlay blurry then not, like glitchy
That is not normal.
There is no blur on mine. No residual numbers . The only thing I see that is "glitchy" is when sliding between the offroad screens, there is a moment when a legacy screen with yellow dials appears and vanishes before the later version appears. Its a pre-production screen that was replaced but is left in the code.
I second that’s not normal.
What is Grenadier normal, is the noticeable lag when selecting different menus. Sometimes if you know what screen has been selected and of the amount of clicks needed, you can select a function by just listening to the clicks….before the screen changes. I do this often when using the center wheel to turn off ADAS (Favorites/ADAS/Overspeed warning OFF).
