How to use Wolfbox G900 Tripro? Video tutorial here!
WolfBox
Supporting Vendor
11:49 AM
LA
Hi everyone,
Are you unsure about the functions of the icons on the screen? Not sure how to adjust the video resolution? Need help setting the time zone and DST? Or wondering how to connect to WiFi?
We’ve got you covered! This comprehensive video tutorial will walk you through everything you need to know about the Wolfbox G900 Tripro. Whether you're a first-time user or looking to make the most out of your dash cam, this video will answer all your questions.
👇 Watch the tutorial here:
View: https://www.youtube.com/watch?v=JAHO7TmF7b4
Please take your time to watch the video and follow the steps.
If you still have any questions or need further assistance, feel free to drop a comment below! We’re here to help.
Drive safe and enjoy your Wolfbox G900 Tripro!
The Wolfbox Team
A just finished my install. I am not going to bother with the front bumper camera since I am really tired of feeding wires through nearly impossible places. I have installed backup cameras on two pieces of out farm equipment, a tractor and bobcat skid steer and the grenadier was far worse. Hints: 1) The videos online give good advice but tend to skip over the tougher parts. 2) get the wired adapter 3) get the antiglare film.
Another hint: 4) putting the GPS pod up in the center overhead console as shown in
View: https://www.youtube.com/watch?v=VRp5RUXvBRI
works just fine for me. 5) Get the 67designs mount, it is a vast improvement over rubber banding the Wolfbox to the existing mirror. 6) You can tap power from the overhead console and just put the wired adapter up there. Use the Yellow wire and the mirror will come on when the vehicle is turned on. I just covered the red wire and left it hanging. 7) Putting the camera centered inside the rear window works great, keeps it out of the weather and you also get the glass cleaned by the rear window wiper so it doesn't get obscured in rain or snow like most backup/rear view cameras do. 8) At least on mine, there was no retaining ring on the rear view mirror but it is very hard to pop off. Just hold on tight to the mount so you don't rip it off the windshield.
How suitable is the wolfbox for RHD vehicles ? I am considering one, but it looks like the front facing camera on the display itself might not actually pivot far enough to look straight ahead ?
The rear view and the bumper ones are fine, but I need the display to be facing far enough right for me to use it as a viewer.
Just wondering if anyone with a rhd has used one of these ?
It works just fine. I thought the same as you and I had that problem, until clever me realised that you no longer need to have the Wolfbox angled towards you as though you're using it as, y'know, a mirror! Because it's a screen you can set the Wolfbox parallel to the windscreen then the forward facing camera has plenty of horizontal and vertical adjustment to capture whichever part of the view ahead you're interested in.
When I take my vehicle in for service I can tell the techs are not familiar with the Wolfbox because they turn it around like a mirror 🫢
AN update: I was wrong about just using the yellow wire on the wired power adapter. It mostly works OK but at times the floating red wire lets the unit think that the AUX power has been turned off so the mirror turns off. I made up this little adapter so now both the yellow and the red are hooked to power that comes on when the vehicle is turned on. So far it seems to work. I'll let you know if I have further random mirror turn offs. By the way, the anti glare film works great!
Thanks Gene, I’ll be interested how it is plugged on the overhead console. I tried to tap into the fuse box below the wheel using the adaptor and some diagrams from people here but that didn’t work. For now it works great but I have this ugly cable going to the 12V output in the central storage box.
@Clark Kent : You have no idea how many times I tried to look myself in it thinking it WAS a mirror!
I just taped into the power going into the 10 amp EXT1 switch. I didn't want any power vampires so hooked both wires to the one tap using the adapter shown above. The only side effects I can see are 1-it complains about to being charged up when you turn on the vehicle and 2- ir doesn't capture any crook videos since it is powered off when the vehicle is off. If you want it to have power when the vehicle is off then tap the yellow wire into a constantly live wire in the over head console.
