WOLFBOX G900 Tripro Dash Cam - Designed for Off-roading! Up to $50 off
I sense another purchase coming....
Hi wolves,
I installed the TriPro yesterday using the wiring kit and the fusebox next to the steering wheel as many others.
I used the FC04 (5A; clock, theft-alarm) for the yellow B+ wire and the FC21 (15A; 12V front outlet) for the red ACC wire.
Depending on the setting for the Parking Mode, the mirror turns off after a few minutes as supposed either with the message "Disconnect ACC, trigger recording begins" or without any message.
But after a few seconds it turns on again and stays on, even when parking mode is turned off. I guess that's not supposed to happen?
How does parking mode look like anyway? (If G-Meter is activated) Is the mirror on or in dark mode?
Try flipping your connections. Red should be for the Ignition switched voltage. Yellow is the B+, always on battery connection.
That's exactly how I installed them.
Red = FC21 (12V Outlet) = ignition switched
Yellow = FC04 (theft alarm) = always on
If I flip them, the mirror is killed when ignition is turned off, as supposed. But then I can't use parking mode.
I'm using FC15 for Always On B+ and FC23 for the Red/Switched. The Grenadier often stays awake or wakes back up if any of the doors are open or unlocked. FC21 and FC23 shouldn't behave any differently. Are the pigtails on your fuse taps facing right when looking at the fusebox from the driver's seat?
During parking mode, time-lapse recording the wolfbox screen stays off. However, the screen wakes up if the g-trigger is set off. It seems really sensitive so I had to lower the g-trigger sensitivity to "low" in the menu.
Yes, they’re both facing right.
FC21/23 shouldn’t be the problem, maybe I need to try another fuse for B+.
Thank you! Good to know. Is your mirror „shutting down“ before entering the parking mode? With a message similar to mine?
When i turn the key off, the wolfbox displays the message "ACC disconnected, time-lapse recording mode starting" for a second and then the screen goes dark. If i bump the car or slam the doors, the g-sensor triggers and the screen wakes up for a minute and shows recording. After 1-3 mins, the screen goes dark again and goes back to time-lapse mode.
