Australasia how do i remove the auxiliary battery of grenadier?
CRANO
11:17 PM
BULLI
I would like some guidance on removing the rear bench of my grenadier wagon.
I want to remove the second lead acid battery and replace it with a LiFePO4 battery that will run my fridge.
Thanks in advance.
markcranston owner of Bluey
Thanks in advance.
Sorry can’t help you there as mine is a two seater, so battery access is much easier. I’m sure someone on the forum has done it though.
Thanks in advance.
Hi Mark,
If it's just the seat removal you need help with the Goose Gear seat delete kit instructions might help.
Downloadable from Goose Gear here:
Direct file link:
Thanks in advance.
you do not have to remove the rear seat to remove the battery .
You can remove the plastic shroud from around it, unbolt the hold downs
and then slides out underneath the seat .
Hope this helps
