Hi guys- looking for advice
Gday Matt. I’m in the same position, though after taking the leap. We’re a broadacre cropping and cattle operation running 79’s (6 of them) and my Grenadier is the odd one out…and I couldn’t be happier. Sure it is quirky in comparison (those marketing blurbs about how simple the Grenadier is seem to have little idea about how basic a 79 is), but it is both a joy to drive around, and as capable as any of the Toyota’s on farm. Plus it serves as a great conversation starter wherever you go as I’m yet to spot another one. Don’t get me wrong, Toyota have a justifiably great reputation for reliability and access to parts, and are great farm vehicles. They are not completely trouble free though, my wife’s 300 series has had 2 or 3 recalls.
Maintenance wise, the servicing is pretty straightforward, provided you can easily access genuine filters.
Mechanically, I have fallen victim to the front shaft failure, which required the vehicle being lifted back to Brisbane. This is an issue that needs to be sorted, but there seem to be solutions in the pipeline (aftermarket). If it goes again though, I would just replace the joint here.
The only real downsides (bear in mind I’m only 25000kms in) are the weight and the fuel capacity. I think I’ll pull the trigger shortly on a GVM upgrade, and have the BD 100litre long range tank, so that should sort those two out. Electrically I’ve had no issues.
At the end of the day, you only live once. (Even if it turns out to be a lemon in the long run, it’ll be a good yarn to tell at the pub, compared with boring everyone about how I bought yet another Toyota in a long line of Toyotas)
Yeah it would be my everyday farm car. I’m not that far from a dealer, about 40kms away and my local mechanic is a wizard so if need be he’d able to patch the odd item here and there without messing with warranty. It’s a box on wheels, the electrical don’t bother me because they are an easy fix and I can live without them, it’s more running gear and engine stuff that concerns me
As long as you are close to a dealer and it stays open, you should be ok.
I have very early one, 22,000 miles, still issues with HVAC. Awaiting expansion tank replacement, and safari windows still leak when the vehicle is on the drive facing upwards at a 10 degree angle.
Being where you are i am guessing you won't want a glass panel above your head so that's nothing to worry about and as long as the AC works, which as long as gassed it does then you should be ok.
You cannot self diagnose warning faults and clear service reminders yet but that is being promised to be fixed soon.
Yeah mate that was the other route I was going down. Just get a 79 and forget but the lure of grenadier is too much. And the price of the last V8 79s is just nonsense
Y
Yeah no glass above the head is fine for me. I’m not hearing anything too scary so far. That’s good!!
Reactions: CRH
Can you define older models and new models for me please. Is 24-25 models that seem to be more sound?
The newer the model build, the fewer the issues will be as known issues that have a TSB/dealer fix will instead be sorted from the factory line. Effectively, the current Grenadier is exactly the same as the first ones rolling off the line apart from software updates and fixes (and addition of ADAS in certain markets, which I believe doesn't impact on you)
You need to spend a lot more time reading. The b58 is about all you’re gonna fix, or get parts for.
Matt, there are no significant differences outside of ADAS addition. There has not been constant development and refinement. The 23 is basically the same as the 25.
You remind of salesmen I get in the office, making the statements 5 different ways hoping for a different answer. I would NEVER buy this as an only car or a buisiness vehicle. They didn’t pull off the updates or support for that, and we don’t know if they will. Hope and pray is not a buisiness strategy. Read into every success story however you want to fit your desired narrative, but just know, it’s still a dice toss it was 2 years ago.
Reading between the lines and watching the likes of Ronny Dahl and I know you wouldn’t be touching a B58 so what could go wrong?😀
Seriously mine is 53000klms not quite run in and just loves to power on. It’s my seventh diesel and is the best off road vehicle to drive because it has been engineered for that purpose with all of today’s solid running gear👍🏼
