Can you have an LGV as a company vehicle? If so, it might not attract BIK and could be a good loophole now they have shut the door on double cab pickups. Portal axle Grenadier as a company carThe 4200kg GVM upgrade is interesting.
In the UK that would require a different driving licence but also perhaps a tacho? I wonder how one would be registered here. Personal LGV? I also wonder what the implications on BIK would be. At present it’s horrendously expensive to run a 5 seat Grenadier as a company car through a Ltd company.![]()
Can you have an LGV as a company vehicle? If so, it might not attract BIK and could be a good loophole now they have shut the door on double cab pickups. Portal axle Grenadier as a company car![]()
Are these available for the US market? If so I would order two. Just looked at the Phoenix store. Nothing about the portals there.
"https://ineosgrenadier.com/en/us/the-vehicle/grenadier-x-letech"I'm sorry but what web address would that be for the interest?
Me too let me know if you hear anything!! I'll do the same.Found it. Sent my Inquiry.
That would make sense.Carraro has portal axles. Would it be a better option to get OEM portal axles then a small third party cutting and shutting and potentially not being able to supply spare parts in the future.
Hummer H1 has inboard mounted disc brakes near the diffs before the portal hubs so when the truck stopped the brakes would hold and the backlash in the portal gears would allow the vehicle to move back and forwards slightly. Will not occur with the Letech portals because the brakes are still at the wheels past the portals.What do you mean by “rocking” ?
If you need to drive over logs, this could fit the bill
The famous Forest Rover
There are more myths associated with it than any other Land Rover, but the Forest Rover undoubtedly has a charm of its own. Pioneering new research by the authors means we can bring you the full story…www.landrovermonthly.co.uk
Wading depth is less than the standard Grenadier but the price difference from standard vehicle to modified makes the Grenadier to Grenadier with portal axles look to be a similar differential
The French fire service have just placed an order for €160m non portal versions.For that purpose fire and emergency services still rely heavily on the Unimog, all kinds of it.
I know this from (one of) my job(s).
AWo
