Yes, lovely and green throughout!Nice amount of vegetation; has the whole route been like that? See what a few ‘wet’ years will do…
Keep keeping on![]()
For the non-Australian members, it might be worthwhile putting ‘Great Central Road, Australia” into google maps, on satellite photo background. It’ll give you a idea of the ‘normal’ colour of the landscape, and if you zoom out slowly, it’ll give you an idea of how far out there the globalgregors team is.Yes, lovely and green throughout!
OK, good suggestion @James . Pictured below is the journey to date.For the non-Australian members, it might be worthwhile putting ‘Great Central Road, Australia” into google maps, on satellite photo background. It’ll give you a idea of the ‘normal’ colour of the landscape, and if you zoom out slowly, it’ll give you an idea of how far out there the globalgregors team is.
Only Mongolians can compete for how few people there are per million acres out there… good job!
Carpe Diem, and carpe pulvis while youre at it![]()
Quick update having made WA along the Great Central Road…
- Garmin Overlander doesn’t like being shaken about - powers off on corrugations. Anyone else had this issue?
Mine is also hardwired from the (driver) footwell. It’s a bit of a bugger to troubleshoot, but it’s battery shows 100% despite an ‘Insufficient Power’ message.Mine was fine but where is yours plugged in? I discovered that the cigarette plug in my centre cubby box was effectively disconnected. I have my own connection that I brought up from the footwell wires. And mine was fine on the corrugations
Wow! That’s impressive
Got to complete the trans-continent crossing first.Wow! That’s impressiveAnd back ?
Should also be a little cooler along the coast.Got to complete the trans-continent crossing first.
Planning to come back the easy way though (Nullabor/on road)!
Over corrugations the rear tyres want 40+ psi cold to keep operating temps within an acceptable range, at temperature this is ~47psi
Ouch - 47psi over corrugations- talk about shake rattle and roll.
I've run 28 psi on 285s for 1000s of klms without issue, maybe having the tyre monitors is making you nervous, bit like a Rolls Royce I used to own, I asked my mechanic why it didn't have a temp gauge, he said sometimes too much information doesn't make comfortable driving@bigleonski this is on wide open WA gravel, not like track corrugations. 110kph and it smooths out somewhat.
I prefer the feel & handling at 28psi and more like 80-100, but was finding the tyres overheated.
Welcome other ideas as I’m enjoying experimenting with different combinations to see what works best.
I’m also thinking a little more tyre diameter would help, as I’m sure my old Wrangler on 33s smoothed similar situations out a bit better. In mind is the old Bourke-Wanaaring Road before it got tarmac. Pretty hard to get apples to apples as that was years ago.
Quite possible - I’ve been chimping the Offroad screens, being such a data geek.I've run 28 psi on 285s for 1000s of klms without issue, maybe having the tyre monitors is making you nervous, bit like a Rolls Royce I used to own, I asked my mechanic why it didn't have a temp gauge, he said sometimes too much information doesn't make comfortable driving![]()
I’ve wondered whether the Eibach lift is just for that, lift, or additional load as well.@bigleonski this is on wide open WA gravel, not like track corrugations. 110kph and it smooths out somewhat.
Accordingly I emailed Eibach about longer springs…
Just lengthened, I believe.I’ve wondered whether the Eibach lift is just for that, lift, or additional load as well.
Great looking trip and thanks for your updates...we did across the top-end of Oz in 1981 and then the bottom-end via the Nullabor home in an MQ Patrol 3ltr Diesel with hand throttle on.Got to complete the trans-continent crossing first.
Hmmm, sounds like you might have a fault in yours. Mine only drops out when I forget to turn the overhead power switch on.Mine is also hardwired from the (driver) footwell. It’s a bit of a bugger to troubleshoot, but it’s battery shows 100% despite an ‘Insufficient Power’ message.
Love the Tripolina chairs! For a while Autohome in the US made them and I had one, sadly stolen! Just found a supplier in Argentina and ordered a couple. Where did you get yours?Grenadier 1 : Simpson Desert 0
Arrived Mt Dare after a solid two days/one night crossing.
French Line was pretty hard going, temperatures were hot but not brutally so - mid to high 40s with a peak of 51C.
As mentioned elsewhere we would have been closing on GVM, with 80L of auxiliary fuel and 55L of water on board.
We ran the tyres at 16psi front and 18 rear. Pleased to report no punctures/failures.
Didn’t have to break out the shovel or maxtrax.
One particularly talc-y dune took three attempts but everything else the Grenadier marched up and over with minimal fuss.
Reported average speed 20kph, average fuel consumption in very challenging sand was 19.6L/100kms.
Aircon was running full blast (we are safari windows and no tinting) but cabin temperature was no issue.
The overnight stop:
Download the gps breadcrumbs from the pathfinder and you can upload them here. The forum supports Gpx filesLoving this trip/blog..... be great if you could upload maybe the map/way that you went when finished.
Epic trip. You guys could very well be the first to do this in a Grenadier!!Got to complete the trans-continent crossing first.
