Grenadier plug and play Soundsystem How we do it
Thanks Bjorn. I've used the native EQ to up the bass but it sounds terrible. I imagine the sound stage is wrecked doing this. I have the Bit Drive software on the lap top but yet to hook up with the system. Yes if you could send that software to push the amp a little more I will try this option ! Many thanks.
To follow up. Bjorn sent me an updated file to up the bass output. Loaded up the Audison BitDrive software and easily transferred the update to the amp. The result is subtle but noticeable improvement. I've fiddled the BitDrive software a bit further and achieved a slightly better result on top of this. Overall, probably around a 10% improvement.
Hi mmarbach. I've simply stowed it under the passenger seat for now ! Like you, would have liked to install in the front panel in a blank space but that's simply not possible due to the PCB. Not really keen on the overhead solution so for me the issue remains unresolved. Maybe others have a solution ?
If the car have the second Auxilary row we place the DRC controller right in the middle of them. Works fine. We will add this to the manual soon.
Thanks Bjorn. I'm just unsure how this would work given the yellow bits right behind the location between the switches. I was also unable to remove just the cover after removing the screws as it seems to still be attached in the middle somewhere. I didn't want to pull too hard and break the panel. See the attached pictures with the possible location for the DRC remote control circled from the front and from the back of the switch panel. If you have pictures of an installed remote control knob for an auxiliary switch panel that would be greatly appreciated.
That’s great. I’ll be interested in the file as well. Have yet to tackle the install when u have a bit more time.
