Grenadier full insulation
SiMsound
Supporting Vendor
11:07 AM
Wunstorf, Germany
Since most people should be familiar with us by now (keyword: plug and play sound system), we've finally managed to take a closer look at the Grenadier and its full sound insulation, eliminating rattling and creaking noises, etc. Vehicles with Safari windows, in particular, have a lot of catching up to do in this area. In short, with extensive full sound insulation, the Grenadier's ride comfort can be significantly improved!
Just check out our video about it. ;-) I'm looking forward to your comments.
YouTube: Ineos Grenadier full insulation / massive Improvement!
Thanks for sharing. I have purchased your V2 sound system and plan on installing it soon. This helps me think about further installation of sound deading. Having the truck tub in the back, I do pick up more sound resonating from the muffler and over course the metal wall against the rear passenger seats.
Did you meter before / after to get an objective improvement? would also have been fun to see the RTA curve to see the change in resonance.
Yes we do! The measure was while the car was driven with 60km/h (around 37 mp/h). Red curve is without insulation and the yellow with insulation. As you can see. Some freqencies drop down around 5-6 dezibel which is more than 50% less than without the insulation!
That is very interesting. It seems to deal with that resonance at around 40 hz. I'm surprised to see that drop at 200 to 300hz
its decent. Did you use a directional measuring microphone? where did you place it?
Did noise change with direction of the microphone?
I a 6db reduction is a 75% reduction in noise level. Its impressive. 3db is pretty good and i would be happy with that.
My objective is to get the sound reduced in the vocal area, 300hz - 2khz. thats what prevents a good conversation or handsfree from being transmitted well.
Seems like you identified a way to do that well.
I did a full noise reduction in mine, i found the trunk to be the biggest bang for the buck but i did that prior to installing the drawers.
I did all the doors and cavities but not the front floors. Mine is very quiet. Didn't do the ceiling due to effort involved.
@shiv.nandak We did some sound proofing on the inside of the Safari window plastic frame to reduce the a bit. But it will be never so quiet like a Grenadier without Safari windows.
@parb Microphone was placed between the front seats showing up. It´s alsways the same position when we make measurements like this because it´s the position which is nearly the same like your ears. And we don´t change the position because of the best possibility to compare different measurements.
