Grenadier brake line prices & query
CL66SEN
3:33 PM
Twickenham, England
I am looking for a spare set of brake hoses to take with me on an upcoming overlanding trip and have been given the following quote (£915 incl. VAT) from an INEOS dealer outside of London. I am surprised by the cost, does this match what others are seeing?
Furthermore, when I did an online check against these reference numbers, the reply states that these are not valid INEOS codes, as INEOS uses 10-character part numbers starting with GRA- followed by a 3-letter system code, following by a further -two digits for the version. e.g. GRA-BRB-010147.
Any advice and guidance appreciated.
Do you have anyone local who makes them up? They are way cheaper than that,
Buzz Overland would be a good try as they will probably know the specs.
A frustrating day...
I contacted INEOS who told me that the part numbers taken off the schematics shown above from the portal are now no longer available.
I spoke with HEL and Goodridge who both said that they do not do INEOS brake lines and can't help. I also had an email from Agile Offroad - the lines that they have are specific to the aftermarket brakes that they fit and hence are not suitable as OEM replacements.
I tried a few other 'specialists' from online research today, a few of whom had no idea what an INEOS was... no joy.
Alex at Buzz Overland can't help directly, but has given me the details for someone else to contact (Pioneer4x4). I'll give them a try tomorrow.
That’s annoying. I wonder if all the other part numbers on the portal are no longer available? If so making the parts schematic next to useless. I’m hoping not.
OK, let me help you out... I am assuming you are looking for a trail repair
1. There are 6 Flexi hoses.
2. All fittings are M10x1
3. The 4 to the wheels have a male at one end and a female circlip fitting at the other.
4. The two extra ones on the rear axle have female circlip fittings on both ends.
5.The right side ones are the same as the left ones
Some pictures:
M10 male
2 suggestions:
Go to this site and select M10 male and M10 female, selecting the right length of course. About £20 each.
My suggestion however is this_
Go to car builder solutions under self assembly brake lines.
Buy a length of braided hose about £8
Buy some fittings, about £5 each.
You will then be able to make up lines if you damage them. Dead easy as per this video.
View: https://youtu.be/5tdsgZ-KfWI?si=kWijwBV9Myqd8u30
It will save a lot of space and money, you might even be able to help out a fellow traveller as this stuff is pretty standard.
Some pictures:
M10 female circlip fitting.View attachment 7912917
M10 male
2 suggestions:
You are a wealth of information. Good shout 👍🏼. I’m going to get hose and fittings for my spares kit. Thankyou 🙏🏼
