Hey Guys! AJ From GP Factor. Excited to be a part of this forum as a vendor and lifetime member!
If you are unfamiliar with GP Factor, we produce high end vehicle parts and camping gear in the USA. We have prided ourselves on making parts that do not compromise on quality, and provide years of hard use. We had announced earlier this year that we will be making a full line of parts for the Ineos Grenadier. Currently, we produce one of the best folding tables on the market. We are excited to announced and give you all a sneak peek to the version we will be releasing for the Grenadier! This table is currently based on the same proven design we have made for years for Jeeps, Campers, Broncos, and Land Cruisers. It will be sized and specifically designed for the Grenadier. The specs of this table for your Grenadier as follows:
  • NO drilling or modification. This will use the existing factory bolt riv-nut locations so installation is super easy. You could even use your factory mounting hardware.
  • It will come with our patented cableless hinge design that is both durable and easy to use.
  • Table is made from food Grade 304 stainless
  • One handed dual latch design for easy closing and opening
  • All tables include a ½” bamboo cutting board that can be removed for cleaning or flipped over for dual sided use.
  • We will be releasing a second version of this table that will have a compartment built into the backer (like the factory plastic piece)
FULL LISTING FOR THIS TABLE CLICK HERE: GP GRENADIER FOLDING TABLE
We will be opening up preorders for these in a few weeks and plan to ship the first batch in January/Early February 2024. I have also included in this post some pictures of our existing tables for reference.
You can also find a lot more pics, videos, and other media on our existing tables on our Instagram or website - @gp_factor
We will be releasing other products soon (maybe some stuff you all have been requesting…) for the Grenadier so keep an eye on our vendor area of the forum and also subscribe to our email list as well on our website – Gpfactor.com
Thanks and let me know if you have any questions! Cheers,
I think it’s fantastic how your 3 pc design allows for different center section options which sets your bar apart from other offerings out there. Curious if you could add just one another option for a curved center top bar and straight lower?
  • Standard bar (lower curved center bar)
  • Double curved center bars
  • Double straight center bars
  • Curved top and straight bottom center bars
@GPFACTOR - are the light cradles bolted or welded to the crossbar? Curious if one decided not to add the lights but likes the future option.
They are welded to the bar to make sure they are as close to the grill as possible and also no wobble in those LP9s. So if you have an existing bar and want to upgrade just email me and we will take care of you. But you can buy the bar with the mounts and put lights in later for sure.
We can definitely do that no problem. Just send me an email and we can make that for sure. take baout 3 weeks to ship but we can do it
Do you guys happen to have a front license plate bracket? I went through a car wash this past weekend and while going through the blower, it managed to snap it off. I need something stronger than the OEM bracket.
Do you guys happen to have a front license plate bracket? I went through a car wash this past weekend and while going through the blower, it managed to snap it off. I need something stronger than the OEM bracket.View attachment 7912578
We only have a front one that works with our winch kit, not the factory bracket. We will look into it
Options:
Fits Grenadier
Good Morning Grenadier Fam! We are excited to announce the launch of our GP Jetpack Diesel Heater Kit for the Grenadiers! Pre-Orders are open now and first batch will be shipping end of December. Details are below but here are a few easy answers to common questions:
1. Kit comes with the Webasto Airtop STC2000 3.0 Bluetooth Heater Full Kit
2. Kit includes all the parts needed to install less any extra wire length needed to power if you are not going to your under seat batteries
3. Fuel tank included
4. Yes, this removes that small rear window and seals in that spot the same as a window would. We recommend having a qualified shop remove your window for you. We had ours removed for 50.00 by a body shop so its not costly or time consuming.
5. Kits will require assembly of the Webasto parts in the kit pieces. Detailed instructions will be released closer to shipping date in December. Its not difficult. Just wanted everyone to be aware
6. Kits will come with the Webasto only. Its a solid reliable heater so we didn't want to pair a kit like this with the knock off heaters that brake alot easier.
7. Outside and inside panels are completely removable for easy maintenance of the heater when needed.
Let me know if you have any questions. Cheers!
INFO: https://gp-factor.com/products/ineo...esel-heater-kit-w-webasto-airtop-stc-2000-3-0
GP Jetpack Heater Kit for the Ineos Grenadier
Turn your Grenadier into a true four-season adventure rig.
GP Factor proudly introduces the first product in its new GP Jetpack line of vehicle heater systems — the GP Jetpack Heater Kit for the Ineos Grenadier Station Wagon. Designed for seamless integration, this turnkey system allows you to install a thermostat-controlled, diesel-fueled Webasto Airtop STC 2000 Bluetooth 3.0 heater without compromising your vehicle’s rugged aesthetics or cargo space.
Precision-engineered to fit directly into the Grenadier’s rear door, the GP Jetpack system follows the vehicle’s natural lines, maintaining a clean and compact profile. Despite its low-profile design, it delivers exceptional heat output — perfect for keeping you warm through long, cold nights off-grid.
Each kit includes a removable interior vent panel and exterior service cover for easy access and maintenance. The system is built to recirculate cabin air, maximizing both heating efficiency and fuel economy — so you stay comfortable while conserving energy.
Included in the Kit
  • Fuel Tank – 3.3-gallon diesel tank with a vented Radium Engineering fuel cell cap.
  • Heater Unit – Genuine Webasto Airtop STC 2000 Bluetooth 3.0 heater and all required accessories.
  • Finish – Durable black textured powder coat exterior, with a gray powder-coated interior vent panel.
  • Mounting Hardware – Custom bracket for internal fuel pump mounting, all fuel lines, and a starter electrical harness for easy vehicle connection.
Engineered for reliability, efficiency, and seamless integration, the GP Jetpack Heater Kit is the ultimate upgrade for transforming your Ineos Grenadier into a year-round exploration machine.
This looks great. But, only recirculating internal air means there will need to be a vent somewhere else. Either a window left open or a dedicated vent.
Exhaust fumes likely to blame.
The exhaust fumes go out the back of the truck through the outside box, plus this typically is used with the roof conversion with temp popped up. Always Reccomend a CO monitor just like a house of course.
Do you have a U.K. supplier?
Good Morning Gren Fam! Just letting everyone know - Black Friday sale is live over at GP Factor. Sale runs Now through Dec 1. We do not run sales ever, but this is the one we run yearly. Pretty good savings on Bull Bars and Winch kits. Winch kits are preorder right now, but you can secure a spot and the pricing. Those will ship Early December. Have a great weekend! Cheers!
https://gp-factor.com/Black-Friday-Poster-2025---3.jpg
New Product Alert:
Redarc Alpha 50 BCDC Mounting Kit for Grenadiers with out without dual battery Systems:
https://gp-factor.com/products/ineos-grenadier-redarc-bcdc-alpha-50-mounting-kit
This kit is a must upgrade if you plan to run a lithium battery. Our kit was designed to work with Grenadiers that have a pre-existing dual battery system, or those that do not. Kits are a simple install that mounts to existing factory threaded locations. This kit can be purchased with the REDARC BCDC included or just the mounting kit.
Why do we love the REDARC BCDC Alpha 50?
  • Safer charging than the CTEK parts for lithium batteries
  • Can back charge the truck battery from the AUX battery in the event of a dead truck battery
  • Solar capable
Included in the kit:
  • X1 mounting bracket
  • X3 wiring harneses
  • X1 eaton fuse holder and X2 60amp fuses
  • mounting hardware
Hi GP Factor,
I assume that this then allows the factory fitted aux power to draw from the starter battery and the BCDC back charges the starter from the Lithium house battery (similar to how the factory dual battery system works), or am I way off base here?
Thanks,
Harry.
Hi GP Factor,
Thanks,
Harry.
From what I can tell you have to go into the Redarc app and tell the lithium battery to back charge the starting battery. I don't think there's anything automated about charging the starter battery like the stock dual battery system does.
