do you not put it on your Victoria sponges?Wouldn't know how to check my caster, or exactly what it is![]()
Haha, well it's normally measured when you go in for an alignment, and it's on the paper they give you at the end. But the castor angle is best described by just looking at the image below haha.Wouldn't know how to check my caster, or exactly what it is![]()
As long as he spells it correctly, with an 'e', it's all gooddo you not put it on your Victoria sponges?
I think it's around 45⁰As long as he spells it correctly, with an 'e', it's all good
As he should also do with the angle.
This almost certainly has had a huge effect on your joints life span. This is not a trivial number at all, many trucks are sitting at 2-3° and Ineos was super inconsistent with this setting as they were not actually aligning many of the trucks if not all trucks that went over seas. That left dealers to do the alignments and they would have targeted higher caster numbers as .7° would be considered out of spec. And with all that the reality is the caster should have been set closer to a full 5° to provide more consistent handling.I've had my caster at .7 degrees, so not sure if that help or not. or maybe its -.7, can't remember haha
So with a low castor number, his pinion turned up making a straighter drive line.This almost certainly has had a huge effect on your joints life span. This is not a trivial number at all, many trucks are sitting at 2-3° and Ineos was super inconsistent with this setting as they were not actually aligning many of the trucks if not all trucks that went over seas. That left dealers to do the alignments and they would have targeted higher caster numbers as .7° would be considered out of spec. And with all that the reality is the caster should have been set closer to a full 5° to provide more consistent handling.
So yes, your .7° caster is most certainly your secret sauce so to speak. I would also assume your toe is a bit high to account for the low caster.
100%. It's just that little edge the T-case side joint needs to keep from pinching constantly. The pinch is super light to begin with. Ineos was just so damn close.So with a low castor number, his pinion turned up making a straighter drive line.
I am pretty sure I saw the Ineos spec to be 0-2 degrees. I'd need to look it up to confirm.This almost certainly has had a huge effect on your joints life span. This is not a trivial number at all, many trucks are sitting at 2-3° and Ineos was super inconsistent with this setting as they were not actually aligning many of the trucks if not all trucks that went over seas. That left dealers to do the alignments and they would have targeted higher caster numbers as .7° would be considered out of spec. And with all that the reality is the caster should have been set closer to a full 5° to provide more consistent handling.
Where have you seen that the boot material was ever changed? I don’t believe that’s been confirmed by anyone.I am pretty sure I saw the Ineos spec to be 0-2 degrees. I'd need to look it up to confirm.
It's crazy how tenths of a degree affect the CV boots. The boots themselves are truly the weak point, and Ineos changes the boot material later in production to a sturdier material. I wish I knew where it was cut into production.
Caster per the book is 1.4°-2.6° with 2° being the ideal setting. 0° is, both per Ineos and axle geometry theory, just wrong.I am pretty sure I saw the Ineos spec to be 0-2 degrees. I'd need to look it up to confirm.
Yea, inside info, during early 2025. 100% source accuracy.Caster per the book is 1.4°-2.6° with 2° being the ideal setting. 0° is, both per Ineos and axle geometry theory, just wrong.
And they never upgraded the boot material from what we have seen to date. Maybe you have some inside info? Regardless, it wouldn't help the problem as it's not strictly a material problem.
A friend of mine at Ineos, and I doubt we’ll ever hear that publicly, because it’s a de facto admission of an issue.Where have you seen that the boot material was ever changed? I don’t believe that’s been confirmed by anyone.
