Front prop shaft snapped.
Roy Panton
11:14 PM
Inverness-shire, Scotland.
Hi, had my Grenadier Diesel just over 2 years and 20k miles and just after second service with no modifications or big wheels.
Day before yesterday coming along a single track tarmac road at @ 40mph bit of a bang and pulled in to a passing place.
on getting out transmission oil pishing out under vehicle so had to get recovered to Ineos service centre, luckily only 20 miles away.
Turns out front prop shaft snapped. then punctured the autobox sump with the parts now being sent back to Ineos to approve a warranty claim,.
The vehicle has been used offroad and towing but nothing I would say too taxing and having used everything from SJs through to G/Wagens offroad for over forty years have never experienced a front shaft snapping (half shafts and diffs going bang yes) and was wondering if anybody else has had an issue like this on an unmodified vehicle.
Apart with small niggles and the common issues with door locks, rear door sensor, infotainment, thirst etc :rolleyes: it has been pretty good and a pleasure to tow with.
The shaft itself or did the CV joint fail? The latter has been discussed in a variety of threads - the search magnifying glass in the upper right corner of the page will get you started.
A transmission bash plate is IMO compulsory. A busted trans pan will likely leave you stranded; maybe no big deal if you live "within reach", otherwise you will have a bad day and maybe year.
It will be super important to understand if this was a joint failure or an actual shaft failure. If it's a joint failure it will be important to know if the joint shows signs of wear due to debris in the joint indicating the boot had failed and simply missed at inspection.
Sounds like the same problem I had just over a year ago. I lost all the transmission oil as oil pipes and gearbox thermostat had been damaged by the flailing prop. Also transfer box cables damaged and heat shielding. A transmission protection plate will not help in that scenario. Make sure that the dealer checks for small cracks in the aluminium casting of of the gearbox even though the plastic pan has broken. In my case where the screws that attach the plastic pan in place to the main gearbox there were small cracks that caused a small oil weep. Not identified at the time but fixed with a new gearbox last month.
Apparently my prop shaft failure was caused by a failed or not installed properly C clip on the CV joint.
Hi Krabby, most issues with front shaft seem to be with those that have been lifted although I see Logsplitter here in uk had an issue with the CV joint and think there could be some commonality there.
The only information I have so far is of the shaft breaking as at the time I couldn't get too close with all the oil and me in my church clothes😊.
Updated today that Ineos are questioning my use of the vehicle, with a new gearbox required due to the flailing prop shaft with c clip missing which the mechanic said could of come of after.
well... at least they didnt tell you its normal.
notice... its a recall. its only 6000 cars and it may be an issue, and yet they recall. As some sit here without a recall mocking toyota while, drive shafts joint are failing, drag links are falling off, floors are soaked... Personally, I think it must be nice to have a company that will fix stuff.
Drag links are falling off? This has been an issue for some owners? For anyone concerned maybe just check the bolts for torque.
That is a major concern, are Ineos feeling the heat financially due to the excessive amount of warranty claims and looking to reduce them by any means possible
Sorry Ineos, I used the vehicle off road and then towed a heavy load which caused the failure, I should know better and pay for all repairs myself
Certainly a good idea, but its a consumer product, and losing the drag link at the wrong time could kill ya. The factory screwed up, and its Ineos's job to pin down the production window, like toyota did, to fix it.
My truck came to me with the tie rod and drag links completely loose. The jam nuts weren't even touching. It's honestly amazing nobody got killed early on. Hopefully this isn't an ongoing problem.
It’s honestly amazing that Ineos hasn’t done an emergency recall on every vehicle sold so they could check them
It’s also honestly amazing that the QC is so poor they can leave the factory with loose steering components, every other manufacturer has paint marks on vital items to ensure torque specifications has been done
Latest posts
