Americas Front Driveshaft CV redesign
Commodore
4:56 AM
Pasadena, CA, USA
Ineos crew, there is an issue with the front driveshaft CV at the transfer case side. The acute driveline angle generates heat causing the rubber on the CV to rip and spill grease. This leads to failure of the CV joint and ultimately immediate loss of forward propulsion. The failures have been well documented. Do you have plans to redesign this part or should owners start looking for their own permanent solutions?
This is a serious safety concern that needs to be resolved.
Solution
Lynn didn't have the answer to hand but we discussed the CV joint boots failing by the nature of them operating at their extremes in terms of deflection. She took it back to her engineering team and they replied today.
Propshaft angle a hot topic from...
Stu,
They gave a status update that indicated that they where going to discuss this internally. This to me indicates a follow-up is forthcoming, or at least that is how I understand the status update. Should that be marked complete? Seems like it's not even partially complete.
"We shall talk about it" just doesn't feel even like a partial answer.
Personally I have taken the stance that the rzeppa joint is a consumable. Every 30-50k miles it needs to be replaced. I'm traveling with one as as a spare part. Unsatisfying but all other options are worse.
100%
Treating the rzeppa as a consumable is the best option at this time. I am taking the same approach but plan to proactively replace the joint every 15K miles/third oil change. Might be overkill but I would prefer to avoid a failure while on a trip in the back country. Even then carrying a spare is definitely a must.
Agreed. I have one in my roof mounted alubox with the rest of the recovery gear when going on longer trips.
Propshaft angle a hot topic from the very early days of engineering the Grenadier – no surprise there. We worked very closely with our supplier on the development and tested it in extremely rough conditions over many miles without any issues. We now see (and thanks for the feedback) that there have been reports on some rubber boots.
We are reviewing this internally, and with the supplier, and will weigh up whether we believe there needs to be a fix. We have some meetings set up to discuss in the coming weeks. The propshaft angle will be even more critical if lifting the vehicle (>20mm).
@Stu_Barnes
Long post. My apologies in advance.
Action: Please follow up with IA.
There are now a number of threads discussing the front driveshaft CV durability and numerous reports of early failures on standard and lifted vehicles. There is current talk of legal action in the UK and NA as well as NHTSA safety reporting. These are not first-resort reactions but it shows the current tideline of frustration as a consequence of IA's silence and apparent lack of action in addressing broader fleet issues.
Lynn has repeatedly acknowledged that IA are chronically bad at communicating with their customer base and they must do better. I believe Lynn is genuine in her comments. In the interim IA don't appear to have any capacity to address hot spots (including HVAC reliability, PSP noise concerns, service reminder, TPMS pressure thresholds and rotation, etc). It feels like IA transitioned from development mode to a production and sustainment mode far too early and now they don't have the resources to address latent development issues and faults with any degree of urgency.
The driveshaft problem seems to be a spillover from the design stage. The driveshaft and CV technology is proven. The front axle application appears to be comprised by the excessive angle at the Transfer Case. This was never going to get better in production as the global fleet accumulated wear through use and mileage. IA Engineering said in their response they also had concerns about the driveshaft angle but it didn't produce any faults during testing so they never came back to it. That decision is now hurting product reliability, customer loyalty, brand reputation and future sales.
My inner optimist hopes this is a situation where IA will spring a surprise fix on the market that has been in quiet development. My inner pessimist says that IA still don't have anyone looking outwards to take a temperature reading on these early service issues and they are blind to the consequences and the connection to future sales. Even if they have a fix in progress, the lack of communication makes IA look unresponsive.
Stu,
On the back of the podcasts and first AMA round, would you please take these concerns back to Lynn and her team and impress upon them the severity of how this driveshaft issue is being perceived and the impact it is having on their customer base. Please implore IA to:
(1) formally acknowledge the driveshaft issue to owners; and
(2) clarify the warranty position around driveshaft/CV/grease boot failure on vehicles fitted with a modest (IA to define) suspension lift package including levelling springs or spacers*; and
(3) share their progress or plans on a fix for in-service and future vehicles, including the timeline.
You're welcome to share this post and any reactions with IA as a representative view of owner concerns. I think I am reflecting the consensus, or near enough.
Thanks Stu.
*IA said very early and Lynn recently repeated that they would leave it to the aftermarket to develop upgrades and enhancements for Grenadier. A properly engineered suspension lift is almost a given in most markets and IA would have anticipated this. It is not unreasonable to expect IA/Magna to allow for this modification during the early vehicle design, or at least not design the vehicle so critically where there is no margin for suspension height changes. Built for more?
Well written @Clark Kent Thank you!
As an aside we have had a failure reported at 45k on a lifted car in WA yesterday. Lift would be <50mm as that's the limit here.
Cheers
Steve
Thanks Steve. I'm taking a leaf from the playbook of our honourable forum envoy, Mr @Tom D and stepping up to do my bit.
We all want this fixed. Instead of saying 'someone really should fix that' I decided it was time to shoulder some of the burden, step up and say '@Stu_Barnes really should fix that'. 😁
This one is for you, Stu (gosh, Leo even looks like me!)
Rhyming Leonardo Dicaprio GIF
IA needs to understand even for those who have not lifted or modified their vehicles the driveshaft failures is still a point of concern. Failures have occurred on stock vehicles both in the form of torn boots and broken retention clips. Any major driveline components failures early in a vehicles life only serves to create doubt in the mind of current and potential future owners. Especially as it relates to on-road safety and overall vehicle longevity.
Are these types failures likely to result in accidents or injuries? If potentially so why delay addressing the issue and putting people at risk? And finally, this can't just be a future production run only solution it has to be a retroactive fix as there are enough Grenadiers & QM on the road now the liability is too great not to offer a proper solution. A brand willing to acknowledge and tackle such issues head-on would certainly be viewed by owners as standing behind their product and supporting their customers... you can't get better PR than that.
Experts: What IS the solution?
If any...
Well, it’s the boot that fails and you lose all the grease so joint then fails. IMO high HWY kms causes heat that would of course soften/deteriorate boot, making easier to damage or just wear, I regularly checked mine as knew it would happen at some stage, so joint was fine and for $300 it’s easy just to replace all.
So either a better boot/protection or a CV purpose built for the angle and transfer case to diff offset…
Someone like Proformance could build I suspect.
Or Ineos acknowledge and redesign… it really is poor oversight.
But after 56000kms I am not complaining, though the dealer just shrugged, as I have a Eibach lift, which they fit from showroom…
When RD’s fails then maybe something will happen…
Given that Jeep etc haven't solved it , how hard can it be?
Hard , it seems.
Find some aerospace engineer. They deal with reentry temperatures, etc.
Reactions: CRH
I accept that Ineos should have anticipated the lifting of the vehicle, but you cannot argue that because the dealer offered it that Ineos should cover it. The dealer is independent and free to offer anything it wishes after all, there are no Ineos branded lift kits.
But it still shouldn't happen, especially on un-modified vehicles 🤬
Yep. This document is included with Eibach Pro Lift kits and the same info is on their website.
"Swimming is not advised , due to crocodiles"
- goes swimming anyway...
Yep as said I am not complaining is what it is, but for a purpose built 4WD a lot will want a lift etc…
As more fail more will complain etc… as they are in the States as a lot more rock crawling.
After a few hours under the vehicle removing and replacing etc… it’s evident it was and is an oversight, and as said it’s a shame as so much else is very well designed.
Was thinking the trans/box could be spaced down to alleviate angle maybe, but smarter people than me around.
They added this later.
I had the springs on order as soon as they were available for sale and my truck had not yet been delivered.
There was no warning at that time.
I had my lift installed myself, but many trucks were sold modified, or offered to be dealer modified at purchase.
In the US when a dealer offers modifications or has a modified new vehicle for sale, there is an implied warranty.
Ineos may not have liability due to the lift, but we all know that no dealer sold it with any driveshaft disclaimer.
For the US, this is barely considered lifted. The minimum that typical pickup drivers do is a leveling kit.
It sucks that this small spring change equates to Ineos dismissing the problem.
I still love this thing.
I've thought about it a lot, but I don't think it's possible to relocate the transfer case since it's integral with the gearbox and engine.
It would mean relocating the entire powertrain 🤯
I keep reading here that stock, unmodified ones are failing but I’ve not yet read one that has, at least that I remember. Granted, I’ve been reading here consistently only about two months…Will he who experienced his unmodified CV joint fail please stand up and share?
