Americas Front Driveshaft CV redesign
Commodore
11:21 PM
Pasadena, CA, USA
Ineos crew, there is an issue with the front driveshaft CV at the transfer case side. The acute driveline angle generates heat causing the rubber on the CV to rip and spill grease. This leads to failure of the CV joint and ultimately immediate loss of forward propulsion. The failures have been well documented. Do you have plans to redesign this part or should owners start looking for their own permanent solutions?
This is a serious safety concern that needs to be resolved.
Solution
Lynn didn't have the answer to hand but we discussed the CV joint boots failing by the nature of them operating at their extremes in terms of deflection. She took it back to her engineering team and they replied today.
Propshaft angle a hot topic from...
I haven't read this whole thread yet, so I apologize if this has already been asked, but what is the part I've circled in red? It looks like it might be a point of contact indicating the axle hit the side of the housing (and probably pinched the rubber boot)?
The boot is still in good condition. So far, no cracks have formed. I can't explain the scratches. Actually, there's nothing rubbing there. I'm going to the dealer today to get new locks. Maybe he has an explanation.
Propshaft angle a hot topic from the very early days of engineering the Grenadier – no surprise there. We worked very closely with our supplier on the development and tested it in extremely rough conditions over many miles without any issues. We now see (and thanks for the feedback) that there have been reports on some rubber boots.
We are reviewing this internally, and with the supplier, and will weigh up whether we believe there needs to be a fix. We have some meetings set up to discuss in the coming weeks. The propshaft angle will be even more critical if lifting the vehicle (>20mm).
Thank you for posing the question to Lynn. I do believe that she is going to fix the issues as fast as she can given all the constraints.
So they knew it was an issue from the beginning but thought they could get away with it. I wonder if the suppler provided a joint with a boot made of a different material and later swapped it out for a less expensive alternative for protection. In the current configuration there is no possible way that this wasn’t going to be a problem. Every one of these is going to fail before warranty expiration. They will need to find a solution.
I look forward to hearing what she comes back with soon.
Of all things this seems like a real urgent problem.
Yes it is. To my knowledge, this is the only actual safety issue with the truck. A complete joint failure at speed will have the driveshaft smashing into all sorts of expensive parts and will cause the instantaneous loss of propulsion. This could get someone killed if it happens at the wrong moment.
Enough of these have failed as to cause my local dealer to keep front driveshafts in stock because they are constantly replacing them. Ineos must realize the issue. They are clearly trying to figure out a cost effect solution. Replacing everyone’s front axle with one that has proper pinion angle is going to be very expensive. As more cars get more miles on them the failures will start to rack up. What amazes me is that they haven’t made a production change so they are just adding to the costs of the future permanent fix.
Mine was discovered when my Grenadier was in for the software update. There was no reason they needed to look under the car. Clearly the dealership has decided to inspect for the problem whenever a car is in the shop. I wonder if this is coming down from Ineos or if it is a dealer specific decision.
I just noticed that this is marked “solution”. To the contrary, I don’t see a solution but rather a denial of the problem. What am I missing here?
It’s the official answer from the manufacturer that they provided. The software doesn’t have the functionality to make it as an “answer” as opposed to a solution.
I really don't feel this is a major safety issue. In fact it's a very benign failure mode. The only way it could be safety related is if it strands you somewhere because you let it go to far. Failure is silent for some time, then becomes fairly audible. You will hear the failing joint long before it "explodes". It could cause t-case output bearing wear and premature failure, but that's going to be in extreme cases. These joints won't "explode" and start flopping around destroying everything it sees just because the boot failed and the grease flowed out. Trust me, you will hear the joint long long long before it goes nuclear.
That's certainly the case for a slow boot failure. The exception is the 2 or 3 known cases of circlip failure when the coupling separated and cause secondary damage. A different failure mode but same component.
@Logsplitter posted a follow-up on his event recently. His driveshaft separated and took out the TC oil cooler pipes. He's now getting a new transmission under warranty due to main case impact damage from the driveshaft.
Post in thread 'What did you do with your Grenadier today?' https://www.theineosforum.com/threa...your-grenadier-today.12411127/post-1333351742
Yes, I'm aware of those failures. But like you said, this is a much different and more rare failure mode. It's due to a QC fault not a design flaw.
Question here related to any indicative “noises” with regard to this…
Shitake has the drivetrain vibration issue that was almost remedied by the dealer loosening everything around the T case mounting and “releasing some tension” in the setup. It did return however but is bearable.
However….
Last trip home from the mountain we noticed a significant change in this harmonic extra! Just more of it to be exact, and also intermittent.
Had a good look around underneath and can see no obvious curclip damage or boot material breakdown so 🤞🏽 I’m ok for now.
Happened to see this seepage around the front diff and wondered if this could have been causing the noise if oil level low but it really doesn’t look too bad - a little oil goes a long way as is said! Plus I’ve already had the rear one replaced and was advised that driving was ok if I keep an eye on leakage and oil level. (Which is pretty tricky now the skids are in place 🙄)
Anyway my main question is - what indicators should we be listening for or feeling, to indicate an imminent problem?
Cheers Team 😁
Just a little follow up question..
Seems this prop shaft / drive shaft seal issue is quite common as @Jeremy996 just mentioned in another thread so not overly worrying.
On the oil level side, as it’s pretty hard for me to check easily being away and moving locations plus diff protection fitted and with limited tools to hand 🙄
Am I safe to assume that without drip evidence underneath or any noises, can I use CD temp as a very rough guide to oil usage? I’m assuming I can but 🤷🏼‍♂️
Gwt one of those tools with a small light and camera attached to a flexible arm and screen. Got one, just can't think what it's called this early in the morning. Wasn't expensive.
Borescope/inspection camera.
Endoscope , if you use it to look up your bum!
I'm just bumping this since it is marked as "Solution" even though it isn't solved in the slightest. Hell, Ineos won't even admit that this is an issue.
Solution is the generic term that the forum software uses to mark something as completed or closed out. The purpose of this section of the forum was to pose a question and then present the answer from INEOS.
I’m not particularly happy with the reply from them but that’s what they said. That being the official answer from INEOS means it’s being marked as a “solution”
Stu,
They gave a status update that indicated that they where going to discuss this internally. This to me indicates a follow-up is forthcoming, or at least that is how I understand the status update. Should that be marked complete? Seems like it's not even partially complete.
"We shall talk about it" just doesn't feel even like a partial answer.
Personally I have taken the stance that the rzeppa joint is a consumable. Every 30-50k miles it needs to be replaced. I'm traveling with one as as a spare part. Unsatisfying but all other options are worse.
