You are literally nuking it in this post. First of all there is no possible way filling to the port will cause mechanical failure on these axles. Second you are assuming a tech will check the fluid level. Well, I've got news for you, this is not NASA. The tech will drain the oil into a catch basin full of oil from other trucks. They will look for glitter while they do it at best. The techs don't have the time or patience to use a graduated cylinder to measure the oil coming out of your diff. Nor do they give a damn, it's not their money. They want to turn tickets as fast as possible with as few call backs as possible.
I feel like I am taking crazy pills here, y'all are still using some hand made document out of Africa and saying it's the bible. And oil capacities are not meant to be followed to the T. Oil capacities on these types of vehicles are meant to tell you about what you will need, not what you need precisely.
I mean seriously, if these trucks are such delicate little flowers that an 1/8th of a quart more oil in the diff will blow it up then to hell with the Grenadier and Ineos.
Seriously y'all need to find something better to use your brain power on. And I probably do too, because too many of you guys are lost causes. Literally, the brain power on this forum is incredible, but as it always seems to be, the smartest group of people often can't figure out the simplest things.
Ok, I am ranting and don't overly want to. Time to head off to my office/shop and work on some trucks for a little bit.
I'm not really sure what
"nuking it" means . . . must be some Gen X slang I'm not hip to.
As far as a
"handmade document out of Africa goes," I guess that's your feeble attempt to show your contempt for someone not in your tribe. You should do better.
With respect to an authority on the matter, this
post appears to publish an Ineos service document, and I'd say that's a pretty good authority.
One of the great advantages of being a human - compared to say, a computer program - is that we can adapt to changing circumstances in light of new information. Sure, I've filled diffs up to the fill plug for my whole life, but if I get new, credible information, it seems like a no-brainer to adapt and change my behavior. Kicking and screaming and calling people names doesn't seem like a resonable way to deal with that new information.
For those still mulling it over, here is a hypothesis (an unproven conjecture) that is an example of how Ineos could have gotten to the point where they decided to specify a differential fill level below the fill plug:
1) Carraro is asked to design and supply an axle for the Grenadier. This axle comes with a fill plug that corresponds to a lubrication level that has worked in past applications, including tractors and off-road vehicles.
2) During offroad testing that involved extreme angles , Ineos observed fluid leaving the differential housing via the vent. Alternately or additionally, Ineos detected differential oil foaming during extended high speed highway operation.
3) Ineos techs asked Carraro if reducing the fluid level in the differential to 2.1 liters would have an adverse effect on the operation or longevity of the differential. Carraro replied it would not have any adverse effects.
4) Ineos adopted a specification of 2.1 liters differential fluid to avoid loss of fluid during extreme offroad operations and / or during extended high speed highway operations.
Remember
@Dokatd , you can always look away if a conversation bothers you so much that you have to resort to insults.
Cheers.
