Factory Roof Rails
AusGreenGren
10:31 PM
Brisbane
Hi Guys,
I have considering mounting some thin flexible solar panels to the existing factory roof rails - possible with some polyurethane.
They seem to have a slight bit of movement so I was wondering if they are just a cap over something a bit more beefy.
I dont want to force them off only to find I've broken an unobtanium clip or something.
Anybody have any details on these things
Thanks and Regards
Steve
Hi Guys,
Thanks and Regards
Steve
I have read that some people do break the attachments in the plastic rail when removing if not done correctly. I'm sure somewhere within all this knowledge there is an exploration on to remove them correctly
Yes there is .. I forget the thread. Can search. Also in the online repair manual if you have an account with Ineos.
The plastic roof rails are just clipped into some metal studs on the roof.
ahhh thats what im looking for - I can easily mount some angles to these if that is the case and then mount op the flex panel. - Looking to make something very low profile without going to another rack. I have a full length rhino rack and all the camping gear and main panels are mounted to this, which I can take on / off easily in the shed. Im just looking for a small system that will keep the fridge battery topped up when the main rack (and connections) is off - and will fit under the RR.
So any ideas how to get the plastic rail off - slide and pull, 6ft jimmy bar. ??
Steve
Or how about something like this - Lensun 90w bonnet mounted solar panel
Steve
Yes slide forward to unclip then remove. There is a thread in this:
Thanks guys - Im sure there is a thread - I did a basic search but the size of the forum has exploded in recent times (a good thing) and I end up with 20 pages of results - I probably need to get more tech savvy -
I do like the bonnet solar - that's got potential!! - assuming the panel is not overly affected by engine heat?
Steve
