EXT 5 location
FareGame
4:26 AM
New Zealand
Does anyone have a photo in a right hand drive vehicle of where the ext 5 wires are - we found ext 1 (verified with meter) and according to everything I’ve read ext 5 is meant to be near it but we cannot see it
Look for plastic tape on the vinyl tape, that is attaching the wire ends to the loom. I am finding the photo link now.
Rok Dr Guide reveals all.
HINTS TO FIND WIRE ENDS
Number 10 below (for RHD car). Right near the airbox. Look for the plastic tape on the vinyl tape around the loom. Often wire ends are under the loom and not immediately obvious. EXT 1 and EXT 5 are often taped together (but sometimes they are not). EXT5 comes with the Optional High Load Auxiliary Switch Panel option. If you have the EXT5 switch those wire ends should be there, just expand the search out from the EXT1 wire ends. Some owners found then after removing the airbox. As @Korg states below also look under the guard behind 11 (for RHD car).
I had trouble finding mine even though I knew the location. INEOS hide them well!
All wire ends summerised in a Table here.
Yeah that’s were we looked - the dealer extended one set which turned out to be ext1 - think they did remove the air box to do that too - ineos should just put a DT/P plug on them be so much easier
Great book on info too - have it saved with me
Have to have door buttons replaced so will get them to look again - I want the light bar on switch 5 for power not via battery remotes - using the steady loom it was just a simple matter of swapping the aux lights plug around in loom and I have high functioning normal - light bar and aux off the factory roof button (high trigger) but if can power from 5 can then have just the aux lights going - nicer for highway driving
Well after 3 visits to the dealer they finally located and extended for ‘free’ the ext 5 wire …
Can’t even see where it is and certainly required removing parts to find it
The 10 and 25 circuits are now at the same place
Photo of the area and somewhere down there is the other end
I think you won the prize for the most difficult EXT5 wires to find. That looks like a factory mistake.
