Exploring the HVAC system in detail (with videos)
4:30 PM
United Kingdom
As I mentioned in another thread, I have bought an HVAC system from a 2023 Grenadier. The reason I did this was to make videos about it...yes, really.
Hopefully these videos will be helpful to someone, possibly even me.
The first one is here:
I'd like this to develop into a deatiled discussion about how the system works, so let me know what else you would like to see.
Nick
Unfortunately I do not have the wiring harness for this, so I don't know where all the ground points are. I suspect only one is needed given the limited amount of electronics on the unit.
There is an electrical schematic document in the resources section of the forum that may help with the earth point locaitons
Cheers
Steve
What did that unit cost you? I’d gladly toss a few bucks your way to help cover it. Great job taking the initiative.
Really great info from this vid. I've also been suffering from AC issues, (no cooling in intermittent cases, intense heated air from rear vents with outside temp air from face vents, plus lots of leaking condensation in passenger footwell).
Doing some investigation into those actuators, looks like they might be a MAHLE (might be a resupply from another manufacturer) part used in Audis, and probably many other makes.
Thank you very much, that is very generous, but actually the unit only cost me just under 90GBP delivered, so I could not resist! Goodness knows how much a new and complete unit would cost from Ineos, but I suspect ten times that amount, if not more. Depending on the state of my unit I may be able to re-use some of the actuators, assuming they are all working. My worry is that the issues may be control related, and that's a very different story...
Thanks for posting this! I was told by my workshop (Hedin in Danderyd, Sweden) that the electric heater is on all cars but that it is only active when the system is in the "auto" setting (until the coolant reaches the right temperature).
Is anyone else experiencing cold air entering the passenger footwell via the recirculation duct? If so, have Ineos been able to fix it?
Nick
Is
These may be of some interest.
I have been meaning to dig into this issue and see whether a simple reccontrol of the lin actuators might improve things but haven't gotten around to it yet.
Interesting to see the col air bypass gap though, might start to explain how you can get cold from one vent and hot from another.
Tristan
How many degrees did the actuator rotate when looking through the bore scope?
How many degrees of rotation does it take to open and close the valve on the spare unit?
Could it be the the actuator and valve are not zero'd at assembly? So the actuator can not either fully open or fully close the valve, depend on the mismatch at assembly.
Do you have the ability to drive the actuator on the spare unit?
Nick
Nick,
I posted a couple of comments on your first video but then thought that this was probably a more appropriate place for them. Firstly these are very interesting videos and I, and I am sure many others, are grateful to you for taking the time, trouble and expense of producing them. I have been impressed over the winter by just how quickly the demister vents in my MY23 petrol Trialmaster start blowing warm/hot air, something that happens long before the engine can be warm and far sooner than either my 2007 Defender or 2002 Disco 2 used to do, and in the absence of any kind of FBH on the Grenadier I can only prsume that this is the purpose of the electric heater built into the unit. You have immediately answered one puzzle for me!
In your first video at the point when you are talking about the demister flap I though I saw a second flap below and behind the one you are focussing on. This puzzled me until your second video demystified (sorry!) me - it is the heater matrix bypass flap thingy. I am puzzled by this one since I would have expected there to be something with this function to act as a blend flap to mix hot and cold air to allow the unit to respond quicker to changes in temperature demand or fluctuations in coolant temperature etc. However I don't see how the bypass flap in the Grenadier unit can due this due to the way it is driven by a cam doohickey off the demister flap. The purpose of this is puzzling me at the moment.
The final point is a request. It would help me get the totality of the unit clear in my head if I had a cross-sectional sketch showing the locations of the evaporator, heater matrix, flaps, air outlets and air paths. I've been trying to put one together from your videos but wondered if you had some time if you could perhaps do something like this (I did something similar for the Defender TDCi box and it was so much easier to do when you have a unit you can peer inside)?
I look forward to your next video (I haven't had the chance to watch part 3 yet). Again my thanks.
