General Engine Block heaters for Alaska, Norway, Sweden, etc
Pete Brown
1:26 PM
Anchorage, Alaska
Hi,
Has anyone installed a suitable frost plug engine block heater for the B58 engine? I am concerned about reducing cold start engine wear. If you found one, what model did you use, what wattage is appropriate, how easy was it to install, etc.
Something like this is what I had in mind:
Hi,
Something like this is what I had in mind:View attachment 7874538
I’m curious. Did you ever install the block heater?
I did not. I live in Anchorage where our winters are mild enough that it’s normally not really necessary. We are on the water (Cook Inlet). If I lived 50 miles north, I would give it strong consideration. There is an owner in Fairbanks who went whole hog with a block heater, battery blanket, and other equipment. I may be able to drag up the details if you’re interested.
Thanks for the response! No need for you to go through that work. I appreciate it, though! I love your part of the world.
I reached out to DEFA about a block heater, or coolant heater. I currently have their cabin heater I'll be installing. This is their response:
The biggest issue is they need to be installed in a heater hose, so the inside diameter of the hose is crucial. The plumbing also must allow for coolant circulation when the engine is off. Some vehicles have electronic coolant valves that may close when the vehicle isn’t operating.
We have complete engine heater kits that work with 16mm and 18mm inside diameter hoses, and we have a couple of heaters that would fit other sized hoses available, but I don’t have a complete list offhand. This type of installation sometimes requires sourcing hardware such as clamps and hose connectors, as well as making brackets to support the components.
I recognise that this is now a little far out of my reach, and I don't have the know how to do something like this... But it's something for someone that does lol.
I also just got a local offer here in Germany for the install of a Defa system with contact warmer.
Saying that all other options mess with the complex sensor setup and running the engine in emergency mode assuming somethings wrong when temperatures do not add up, this is what they propose.
Whilst many say they happy with the Webasto diesel heater, garages here say they have Grenadiers coming in with loads of troubles after software updates …
On top of the oil tray contact warmer the set includes a heater for the cockpit.
Still making up my mind on this is worth it, but we will be back in Sweden in winter and last time we hit -20 degrees celsius for 2 weeks, which was brutal for poor little Gren.
Link above gives me an error so not sure somebody went for the same thing.
Timo
Webasto is providing block heaters?
Does anyone have this in their IG?
No. They manufacture a parking heater for the Grenadier.
Block heaters are made by DEFA (and chinese companys), but not specific for the Grenadier yet.
I have the Webasto installed, it works really well.
I have a Webasto diesel heater in my Fieldmaster, and so far it's working well (winter hasn't really arrived yet, so we haven't had temperatures colder than -10 degrees Celsius).
A contact or block heater is better than not using any heater at all, but you should be aware that the power output is usually limited to 300 - 700 Watts so that you can run the cabin heater simultaneously on a single-phase 220 V outlet.
So it's not a warm engine when you start it - more like lukewarm. But it naturally reduces wear and tear, and you reach operating temperature faster. A fuel-powered heater like Webasto can provide up to about 5 kW, so there's a big difference.
On previous cars, I've had both electric and fuel-powered heaters, and the electric heater is something I've used when it wasn't possible to run the fuel-powered one, such as when the car was in a garage or when I was going to drive short distances.
Most "modern" vehicles have an electronically controlled heat management module. So no thermostat. This includes BMW.
Conventional block heaters just won't work with this system.
Understand.
Will have the Defa setup installed next week as I do not trust the Webasto solution for now with too many negative reports and the dependency on the software side.
Time will tell.
I will report back here…
… I do not trust the Webasto solution for now with too many negative reports and the dependency on the software side…
Where are the negative reports about Webasto heaters and relating software problems with the Grenadier? 😳
Not in this forum, tell us more.
Hej.
Did not run statistics on this, but initially I observed the Webasto solution stop working after a Ineos software update with various folks. This is like 2 years back.
I back then had various talks with Webasto as well as Ineos folks, “blaming” the other side. My reading was that there were too few Grenadiers on the road to tackle this. My dealer stopped installing them. Did not ask details as I already decided to give it some time and observe it maturing or failing…
Something was fixed. Feels like they got things working as more and more in this forum got it installed.
When I approached another workshop this autumn, they also reported that they continue having folks coming in with issues and in good old Ineos fashion whenever something causes issues that has been touched by modifications, they say it is not their fault.
So I decided to check for options that do not interfere with tue Ineos setup as tue whole hot cold magic still keeps failing and therefore constant item on my issue list.
So, guess you better check with folks that got it installed.
Greetings.
