DVA Mechanics: Traction Board Mounting System – Fits MaxTrax MKII, Lite & More
DVA Mechanics
Supporting Vendor
2:06 AM
Atlanta, GA, USA
Secure your recovery boards with confidence and zero rattle.
The DVA Mechanics Traction Board Mounting System is precision-engineered to fit MaxTrax MKII, MaxTrax Lite, and other standard traction board sizes. Whether you’re outfitting your rig for overland expeditions or simply prepping for unexpected terrain, this mounting rail delivers rugged dependability in a sleek, low-profile design.
Key Features:
  • ✅ Perfect Fit: Compatible with MaxTrax MKII, MaxTrax Lite, and other MaxTrax board dimensions.
  • 🔩 Mounting Hardware Included: Comes with a custom-fit Mounting Pin Set for fast and secure installation.
  • 🛡 Rattle-Free Design: Included 3M rubber pads dampen vibration and noise on any terrain.
  • 🪶 Lightweight & Strong: Made from high-strength anodized aluminum—corrosion-resistant and built to last.
  • 🧱 Mounts Anywhere: Designed to bolt directly to DVA Side Accessory Rails or any standard roof rail system.
Whether you’re battling mud, sand, or snow, this mounting rail keeps your traction boards rock-solid and within easy reach—without compromise.
NOTE: Does not include the Side Accessory Carrier found here.
1 Traction_Board_DSC00423 Medium.jpeg2 Traction_Board_DSC00382 Medium.jpeg3 Traction_Board_DSC00308 Medium.jpeg4 Traction_Board_DSC00391 Medium.jpeg5 Traction_Board_DSC00419 Medium.jpeg6 Traction_Board_DSC00429 Medium.jpeg7 Traction_Board_DSC00446 Medium.jpeg8 Traction_Board_DSC00459 Medium.jpeg9 Traction_Board_DSC00435 Medium.jpeg10 Traction_Board_DSC00272.jpg
Hi
Can max trax lite be mounted to this? The portion looks very long for it. Can it be shorter so it doesn’t stick out as far? Thanks
