DVA Mechanics - DTP-06-2S to Dual IP65 Waterproof Connector Splitter Cable – Rooftop Power Adapter for Ineos Grenadier
DVA Mechanics
Supporting Vendor
7:43 PM
Atlanta, GA, USA
utm_source=TIF&utm_medium=referral&utm_campaign=DTP_waterproof&utm_content=main_link&utm_term=na
Unlock the full potential of your Ineos Grenadier’s rooftop DTP power port with this rugged splitter cable, designed to power two rooftop accessories from a single factory outlet—without cutting, splicing, or compromising your wiring.
This AWG16 splitter features a single DTP-06-2S male connector on one end and two IP65-rated waterproof connectors on the other, allowing you to cleanly and reliably power external accessories like light bars, camp lights, antennas, and more—even those with delicate wiring as small as AWG24.
Why This Cable Matters:
Crimping small-gauge wires (like AWG24) directly into a DTP connector is difficult and prone to failure. This splitter cable solves that by offering dual accessory connections via IP65 waterproof plugs—ideal for overlanding, expedition builds, and work-ready installations.
Key Features:
✅ Direct Fit for Ineos Grenadier – DTP-06-2S male connector plugs directly into the rooftop factory power port
✅ Dual IP65 Waterproof Outputs – Run two accessories from a single factory outlet, securely and weatherproof
✅ Supports AWG16 to AWG24 Pigtails – Perfect for both high-current and delicate wiring
✅ No Crimping Required – Pre-terminated connectors for fast, clean, plug-and-play installation
✅ Durable AWG16 Splitter Wire – Built to handle the power demands of high-draw accessories
✅ Rugged & Reliable – Weather-sealed and trail-tested for off-road, commercial, and expedition use
Built for Builders, Tuners, and Overlanders:
If you’re running multiple rooftop accessories on your Grenadier, this splitter is the cleanest, safest way to wire them in—without modifying factory wiring or compromising reliability.
Simplify your setup. Power more with less hassle. Get your DTP-06-2S Splitter Cable today.
