UK & Ireland Door handle recall in the UK?
Scotsitalian
10:59 AM
Aberdeenshire, Scotland, UK
Stu,
I received one of the door handle recall emails here in Scotland some months ago but to date there has been no further communication, my service centre tells me they have not been authorised to replace them and have not received any notification or communication from IA at all !!!
can we please ask at the next AMA when IA intend to authorise door lock replacement here in the UK?
2024 Trialmaster in Germany. Mine were all replaced under warranty but still sometimes occurring issue. It’s mostly present / worse in cold and wet conditions. Dealer advises silicon spray in the buttons, which I have read is helpful. But t seems an odd response for something that is a potential safety issue.
I tried to get mine changed back in may , was told there was no spares. Ineos have never chased it up or sorted the locks out while it's been down with ineos for 8 weeks
We logged it with IG customer services along with the date we planned for next visit to a service centre. IG organised it so locks were dellivered to them for that time.
STC did the work. 👍
G
I had them replaced three months ago and were much better, now back to sticking again! has anyone found a lubricant or spray that might help? it seems to be when you fully depress the button. interestingly it is the same door as before that is the issue again so wondering if there might be a deeper issue
Lubricate the latch with some WD40. The latch connected to the door button maybe just a bit stiff.
Before mine were changed I used graphite powder and they were completely trouble free.
Much the same for me. Mine were faultless but replaced under the recall regardless, and now, some four months later the second-row right -hand door has started sticking (it flew open on the first occasion, now I close it and tug to make sure it is shut).
It will be mentioned in due course when the service reset is done, and probably again when the second service is due (and perhaps the third)!
I am booked in next week so will mention it, by coincidence it's the same driver side rear door thats been the issue consistently before and after recall suggesting something more linked to inner mechanism
Stu,
Hi, I had mine done in December 2025 by Grange Ineos midlands .
Have you tried spraying some silicone spray in the button and inside the door latch because it’s not always down to the button. It’s how each and every door is manually aligned. The door stricker may need adjusting.
