Difficult to reach low range...
I hear what you are saying but I can't understand why?
It might be that the torque converter is still applying some torque to the gearbox output when in neutral. (Or the gears are locked when in P)
Both those 2 seem logical, but more likely the first N option, I usually use P with the engine running.
I also think operator apprehension play a part. When I am not in a hurry, and parked on my drive and feeling quite laid back, it goes in easy.
If I am rushing and in a strange place with a trailer in tow and tense about putting low/diff lock in, or worrying about the lever pin falling out then it is sometimes difficult.
As there is no synchro in the transfer box the gears do have to line up. If you happen to have stopped with the teeth facing each other then it won't engage. Rolling forward or back a short distance will fix this. I have also noticed that allowing the lever to move slightly side to side helps. It's tempting to push it hard away from you (RHD) to keep it diff locked as you change ratios, don't do this, it doesn't help. Just allow it to feel its own path forward or back.
I have used low box a lot recently, it is definitely easier to get in and out of gear than it was at the start. Whether that is due to the car loosening up or just me getting a feel for it I can’t say. Just like the old defenders it’s easier to get into gear if the car is rolling slightly, so on a hill allowing a slight roll forwards of backwards makes a difference. If you’re on the flat it can be trickier.
Choosing when to engage low box is the key, do it before you need it not once you’re stuck.
Out of curiosity to see if rolling slowly in neutral made it easier to shift into low range I tried it today. What I found was that when I went very slowly in drive and then shifted into neutral to keep rolling slowly while I then attempted to shift the transfer case, the car stopped. In other words, it seems like shifting from drive or reverse to neutral actually stops the car, whether by auto-braking or putting it into a type of park I am not sure. Can anyone who has recommended a very slow roll in neutral to help the transfer gears mesh up when shifting the transfer case clarify how they accomplish this?
Thanks,
Sean
Mon véhicule a également ce problème. Le passage de "H" en "L" est impossible et cela en respectant la procédure décrite dans le manuel. Malgré plusieurs signalements à la concession le problème n'a pas été résolu. Je viens de constater et de vérifier, qu'en fait, tant que la température d'huile du transfer n'est pas égale à au moins 30° C il ne m'est pas possible de passer en "L". Au dela de cette température le problème disparait et le passage en "L" devient possible.🙄
Thanks,
Sean
Hi Sean, I drive slowly in the D position, then shift to N and when the vehicle is only rolling very slightly and almost stationary, I shift the gear reduction lever. It then easily goes into low without any noise in the gearbox. As I have been doing this more than once a week for more than 2 years, it is completely automatic, even when I am distracted. Hope this helps.
Unfortunately today I entirely failed to be able to get mine into low range. I have had in low range with centre diff unlocked before and it went in quite easily but today I could lock the centre diff but no low range. This is potentially a big problem, I was on a track with some pretty knarly bits and there was some risk that I could get stuck, unfortunately that also means that there are no front and rear diff lockers available to you either because INEOS in their wisdom have made it a condition of use to be in low range. Fortunately the car is impressive enough that it managed even some quite knarly bits in high range with centre diff locked. I also had shovel, Maxtrax and winch and recovery gear if it came to that. But a bit bummed about this, tried all the tricks mentioned in this thread but nothing worked so I guess it’s off to the Agent to look at it. 😡
haha indeed... https://www.theineosforum.com/threads/diff-locks-in-high-lock.12418634/
Not being able to going to low range is problematic! This should be a smooth process! Also locking the diffs should be allowed in 4HL.
I had my transfer case checked out by the mechanic out my Ineos Dealer today. I thought my transfer case was very stiff, and sometimes it rattled when going from high to low range.
The mechanic looked at it, he stopped put the car in Neutral, and flips it into low range without any effort. He said the transfer case feels normal.
Then I tried again, when the mechanic was looking, and I still had troubles. He explained that you should use some force and swift motion.
That was indeed the trick, when using a bit more force, and a bit more speed, it flips into low range without any trouble, every time we tested it, it worked, no issues whatsoever. Tried it 4-5 times. And in the way home, i tried again, worked without problems 4-5 times.
So in my case, it was a clear example of user error :) Hope somebody learns from this!
Good result. Mine still takes a lot of effort and needs a lot of force if not rolling forward or back in neutral.
