Thread pitch is M10x1.0. I used straight connectors. I didn’t have enough room to fit elbows. You can check this thread for the parts specifications on what I bought.I’m looking to add raised diff breathers to my Grenadier but still trying to mull over the Ineos design. I understand the original breathers are designed to maintain a certain pressure in the diff, only low pressure maybe 2-4 psi. Does this pressure help to keep water and other contaminants out ? And if so what negative effects would putting a raised breather in for each diff that doesn’t maintain any pressure in the diff have ? I understand from this forum that weeping axle input shaft seals are being attributed to blocked OEM breathers, but some have had input shaft seals fail after they have fitted raised axle breathers.
For those that have put raised breathers on, what fitting have you used at the axle end. The OEM fitting I think is a 10mm x 1 looks like a tapered fitting, but I can’t find any barbed 10mm fittings with a tapered thread online that I would need to fit the breather hose . View attachment 7908006
Perfect. ThankyouThread pitch is M10x1.0. I used straight connectors. I didn’t have enough room to fit elbows. You can check this thread for the parts specifications on what I bought.
Tom’s breather kit.
I honestly cannot see how. That said, it was noted on my 12-month service that I fitted extended breathers.Any chance a warranty would be denied after adding a breather?
