Diff reliability
I think you’ll find that the diffs have been quite reliable. Engaging them is slightly tricky with the double push. Disengaging them is another story - be ready for large steering wheel turns to turn them off. Definitely harder than the quick on off in a Ford and not something you want to do on and off all day.
They disengage when you unlock the centre diff. The telltale lights are what take a bit of twisting to extinguish.
Actual disengagement doesn't seem to be the issue. Problem being you can't lock them again until the computer decides they have been unlocked..
I recall there was a change of mind software update for MY24+. If you disengaged diff locks you could re-engage them again without the vehicle waiting to confirm disengagement via the wheel speed sensors.
Is it double push for offroad setting and a single for the diff lock?
I got mixed up when I first got mine and went back to the dealer to be shown that I'm an idiot 🤣
I am yet to meet the rapid lock- unlock-lock scenario but as they say YMMV.
During my test drive (m y 2025) the salesman had a tough time disengaging the front and rear diffs. I tried first under his guidance. no luck. Then he tried on his own after I got out. That caused some concern for me.
Subsequently, I started to consider vehicles without the locking diffs, as I don’t think I would need more than the center locker, for my use case. Then, I stumbled upon a thread suggesting no one would want the vehicle after me without the diffs. 🤦
Reactions: CRH
Subsequently, I started to consider vehicles with the locking diffs, as I don’t think I would need more than the center locker, for my use case. Then, I stumbled upon a thread suggesting no one would want the vehicle after me without the diffs. 🤦
If the tyres aren't screeching on tarmac, it's just the software that's not registered the disengagement.
mine never seems to have an issue unlocking, but the light does stay on for a while. You can definitely feel when they unlock which is basically right when you push it.
That's my experience as well. Just wish could re-lock (MY23) without them having to stop flashing.
Thats true, I guess I haven't run into a situation yet where it made a big difference for me. Rare that I have needed to engage the front and the rear may drag a bit if locked but doesn't seem to make a big difference on most of the stuff I am running around on. I guess on high traction (rock) surfaces it would make a bit more of a difference.
It is a double push for off road mode and a SINGLE push for rear and front diffs. People always get this mixed up, double push the diff buttons and end up getting frustrated.
I use mine a lot to help crawl out of very soft sand and have not had any issues. Another SINGLE push to disengage and off you go. The lights will stop flashing after a a few seconds, the difference will disengage as soon as you hit the button.
If you keep on jabbing the button trying to get them to engage out disengage you’re going to have problems. ONE PUSH ONLY.
