Diff oil level measuring tool?
There is a flaw in early breathers. I am happy yours is not among them, nonetheless it is a problem.
You do understand these have nothing to do with each other right? The problem you're mentioning would exist regardless of how much oil is in the diff.
i'm corn fused. ....
heat (T) is caused by friction (u) . i can't take an equation and directly substitute friction for heat. and how does friction "cause" pressure, that's heats job? ln(P2/P1) = (ΔHvap/R) * (1/T1 - 1/T2). I'm not seeing friction in here. ironically, diff fluid mitigates friction, as that's why its there in the first place. I'm not certain how 4 more oz of fluid is going to cause friction and therefore heat. The only way more oil could be a functional part of your theory, would be the ΔHvap, but if it really was that much pressure (which its not, btw as more oil would be a heat sink as it touched the casing) that's what the valve is for. so, if your seal is leaking from pressure, its not the fluid, its the breather not working, and more fluid will not cause a breather not to work as it cannot be filled to full or close to it. the location of the fill hole is deliberate. notice its not on the top? its where it is so it cannot be overfilled and prevent any sort of drag or foaming. the gear needs to slosh thru it and spray it, not be submersed in it. plenty of space is maintained.
If they want you to fill below the hole, it's because the oil will expand a little with the temperature, and leak out if opened when warm, if filled to the edge when cold. If you feel a few drips leaking out of the diff hole on the off chance you open the plug when hot, is going to change the crash course the planet is headed on, by all means, buy a special tool to measure. I've given up on saving the planet. I'm sticking with my pinky.
My point was only as these diffs heat up they build pressure internally and overfilling them exasperates the issue. I changed the differential fluids on my rig and the sound of air escaping the differentials when I pulled the covers was audible after a drive to get them up to temperature.
Unfortunately, per my dealer, trucks are still blowing seals even with the aftermarket arb vent tubes which simply vent to atmosphere. So that would lead one away from concluding it's the factory vents that are the problem. Regarding ammount of oil and filling procedure, we should have full clarity with the release of the factory service manual, correct?
Filling to the hole bottom does none of what you are attributing to it, and valves are not free flowing holes. If its to let air flow in both directions, SOME pressure or vacuum is required to open.
Am I to understand you pulled the valve cover off, without the drain plug being pulled? I'm not understanding. Wouldn't you pull the plugs and rain before removing the cover? if so, where would the air pressure come from?
My experience... I filled the diff with oil until it started to drain out, just like I've always done. After freeway driving the underside of my Grenadier was covered in gear oil. Stuck breather? Maybe? I drained a little oil out of the diff and haven't had a problem since. Next time I will fill the diff with 2.1 liters as specified by Ineos and not fill till it spills out.
This issue has been discussed several times before. The proper level is 23mm or about an inch below the fill hole
