Are you supposed to replace that gasket? I was told to reuse it and have not had any issues in 6k miles.Is this the washer you are looking for ?
I have 2. One for each diff, so I can’t spare one.
If we get the manuals, we will know exactly why we can no longer use these tools.. That’s exactly the tool that the technician used when checking my diff oil levels in South Africa
.308?I have 2. One for each diff, so I can’t spare one.
Have you considered your local auto parts store or Amazon if the dealer is out? You may have to bring the old one with you to cross-reference.Has anyone found a source for this O ring here in the States? Thanks
When i did my diff fluid change, i assumed i could just fill until it dripped from the fill hole. But that is not the case!! I carefully measured the fluid and it was nowhere near the fill hole. I even added an extra 100-200ml and it was still no where near the fill hole. I didn’t want to add more for the fear of breaking something due to overfilling.
Please do not do this. It is old school thinking (nothing wrong with that usually) but overfilling the diffs in the IG will result in over pressuring the cases unless you opt for old school vented housings which will cause them to leak.Id say this is a minimum not a maximum. I'd fill until it drips from fill hole like every other diff out there. Otherwise if I can squeeze my pinky in the hole and get a drip of 90w on it then it's also good.
Keep in mind this oil is splashing everywhere even at 5mph. So slight variations in oil level will not make a hill of beans difference up or down. Just changing caster from min to max will change how the tool reads.
Fill it till it drips and run with it.
I'd love to hear your explanation of this. Please site information if you could please.Please do not do this. It is old school thinking (nothing wrong with that usually) but overfilling the diffs in the IG will result in over pressuring the cases unless you opt for old school vented housings which will cause them to leak.
Heat equals friction, friction causes pressure, pressure causes leaks. Your 1990 F250 has an open vent. Your 2024 Grenadier has a slintered vent that is not open and prone to over pressurization when overfilled and when overfilled causes leaks, it is a known issue.I'd love to hear your explanation of this.
I assume you mean sintered vent? Are you familiar with what those are? I assume you're suggesting that the sintered vents get clogged over time since it's allowing air in and out? Sintered vents used as bi directional vents can easily clog to be sure. They are typically best when used as exhaust only. So, yeah if your vent gets clogged you will have issues. Won't matter how much oil you have in your diff. A clogged vent has nothing to do with proper oil level. Unclog your vent as part of regular preventative maintenance and all is fine. Or feel free to add some extensions with or without goofy K&N filters from Pep Boys. Your call, but doesn't change a thing in regards to oil level.Heat equals friction, friction causes pressure, pressure causes leaks. Your 1990 F250 has an open vent. Your 2024 Grenadier has a slintered vent that is not open and prone to over pressurization when overfilled and when overfilled causes leaks, it is a known issue.
Do a DIY vent or something like this if you choose to be old school. Oh, and don’t a such a millennial unless you know of what you speak.
ARB Differential Breather Kit for INEOS Grenadier by Agile Offroad » Agile Offroad
ARB Differential Breather Kit for INEOS Grenadier by Agile Offroad. Upgrade for malfunctioning factory one-way breather valve known to cause leaks.agileoffroad.com
Best of luck to you.I assume you mean sintered vent? Are you familiar with what those are? I assume you're suggesting that the sintered vents get clogged over time since it's allowing air in and out? Sintered vents used as bi directional vents can easily clog to be sure. They are typically best when used as exhaust only. So, yeah if your vent gets clogged you will have issues. Won't matter how much oil you have in your diff. A clogged vent has nothing to do with proper oil level. Unclog your vent as part of regular preventative maintenance and all is fine. Or feel free to add some extensions with or without goofy K&N filters. Your call, but doesn't change a thing in regards to oil level.
And trust me, I very very much know what I am talking about. You my friend, I'm not so sure about. I'm certainly not sure why you think I am a millennial. I was already a Land Rover tech when many millennials were born.
No luck needed buddy. No leaks on my diffs eitherBest of luck to you.
There is a flaw in early breathers. I am happy yours is not among them, nonetheless it is a problem.No luck needed buddy. No leaks on my diffs either![]()
