Death wobble
So you are doing long runs at 100mph? Long being 30min plus at constant speed?
To be fair, I have had mine over 100mph, but on good smooth roads. The truck always does fine on good smooth roads.
Pretty standard fare for the smooth wide autobahns in Europe. You'll be in the slow or middle lane only at 100mph ;)
Agreed, but the Grenadier was certainly never meant to travel at those speeds for sustained periods. I'm not one to complain because I used to cruise my real D90 at 85mph+ upwards of 650miles at a time. And I developed a custom OD to allow my Unimog 1300L to do over 80mph. I'm not scared of speed is my point.
But back on point, a smooth Autobahn at any speed will not display the issues with the Grenadiers steering. Our Autobahns here in Texas are not smooth by any standard. And the Highways in Colorado are famously total disasters.
So the wobble can be blamed on your roads? Lawyer up 😃
You would not drive at that speed for more than thirty minutes as the transfer case gets hot and you will get an oil pressure warning.
The handling- at least in my world- does not get better or worse when driving longer at a certain speed.
And regarding the smoothness of the choosen road I don’t see the need for going that fast on a gravel road or a bumpy side road
Given the aerodynamics, I'd be curious how long a full tank of gas could sustain 100mph.
Given that you do not get a overheated tranfer case it would be short to 350 km with a diesel and presumably less than 280 km with a petrol engine…
(The consumption has been 26,5 litres of diesel/100 km)
I certainly wouldn't drive much above 80mph for more than a few minutes at best.
Handling does not change based on time at speed, you just don't care as much when driving 30min vs 4hrs.
I'm not talking gravel roads, well they aren't supposed to be gravel but they might as well be. Rather I am talking regular highways in Texas and Colorado. Colorados roads just suck. Texas roads are perpetually under construction it seems. These are roads that regular vehicles are traveling anywhere from 70mph to over 90mph for very long durations.
I'm just not sure where the disconnect is here, there are plenty of people that have reported handling issues. Maybe you are one of the lucky ones without. Or maybe like others you have just accepted the poor handling and just don't care because you don't know how great it is when they drive right. Well, mostly right.
I find it interesting that those with handling issues are accepting that others don't have the problem, but those that don't seem to have any issues are adamant that the people with issues must be pussies, Dandy's or just plain old Mall Crawling complainers and they need to suck it up or sell their truck and get a Subaru.
Im
Not telling you that you have a problem, I'm telling you I have a problem. A problem that I have mostly resolved. I have tested the truck in multiple configurations one of which allowed Death Wobble. That's real Death Wobble not just a jiggly steering wheel like I suspect most are thinking of.
Not meaning to be snarky, just a bit perturbed at the moment
Got it. Could be the case. In my case the damper combined with Panhard rod bushes worked. Of course I am not sure if those measures just mask the root cause. I will change steering ball joints. The rest was declared fine. Trialling arms bushes seem okay, but are 8 years old polybushes. Two failed already and disintegrated in the rear left trialling arm. So maybe this might be adding to the root cause as well. If I would change them as well I would run out of any more suspects adding to the prob at my vehicle. Wheels seem okay with 2,4 front and 2,6 back. Wheel bearings are fine w/o play, steering relay and rod okay. Hmmm... BR Sven
For whatever it's worth, Panhard rod bushes are by far and large #1 cause of death wobble on all solid-axle, coil-sprung Land Rovers.
Reactions: AWo
Im
Actually I just added my point of view and experience as outside Germany there are not so many roads where you can drive at that speed legally.
I can’t see where I judged anyone or questioned an experience someone else made.
Nor did I suggest that I have more experience or someone else has less.
I don’t know your experience and you don’t know mine. So we share it here.
Probably the cars have differences in handling.
But we will not know the variety if we only want to hear the things we experienced ourselves. Hopefully we all know that it’s better to come out of our bubble or echo chamber from time to time.
Best regards
bemax
Reactions: AWo
Naohiko-san, on your Instagram there is a post with your Grenadier saying you had fitted 255/85R16 tyres on steel wheels which is unusual (if the translation is correct on the size). Did you have any issue with the brake clearance on the 16 inch steel wheels?
Hi
Thanks your reply
Death wobble had not my green grenadier.
Tire size doesnt matter
I use 255-85-16
Use Sprinter van wheels.no problem.
I found death wobble reason
Oil leaking from Steering dumper so no working steering dumper.
When I change steering dumper(just got from My green and change it)
Fixed.
Hi
Thanks your reply
I use 255-85-16
Fixed.
Yep, failed or no damper is a sure way to eventually have death wobble on. Grenadier (At least the station wagon). The Grenadier needs a damper to keep this condition under control. It's very likely the reason Ineos chose such a heavy damper. They wanted to guarantee no issues and kinda went over board.
I have my adjustable damper set just a couple clicks above the point that I have issues.
