Americas Custom Equalizer Settings-Premium Sound
9:59 AM
Kansas
Has anyone messed with the equalizer on the custom settings? Any recommendations?
Just a bit. Pretty sure my “premium sound” sub is not adjusted, aka not doing anything. Will report back after I have had time to mess with it.
I don't know enough about equalizers to override some of the stand music options they have in the system. At some point, I'm going to take mine to a stereo place and have them fine-tune the sound system.
Take a pic of the settings for us? We’ll call it the peasant-custom tune!
Mine was not turned on, then when it was turned on the sound was terrible. Need to figure out some way to adjust, need to figure out how the custom tune works.
Setting a custom EQ helps a lot. Make sure to hit the save button at the bottom when you set it up. The EQ needs quite a bit of mid (1K) removed, as most all cars do. Boosting the higher frequencies really seems to lift the soundstage from knee level.
Boosting the lower frequencies (scooping up to a lot of 60k) seems to give a much better presence. The speakers seem to be able to handle much more power than the stock ( I have the non premium) amp puts out.
Can you post a pic of your equalizer settings?
@thale10
