Coil Springs (specs v build)
Just to add to this, as I currently have a broken spring and I want to replace it with the +30mm versions ideally as part of the warranty repair. I have written to my dealer but have no reply as yet.
One thought I had is that I remember reading somewhere that the African spec versions were fitted with the taller spring from factory? Can anyone confirm this? They’ll presumably have a different part no. Can I ask African owners take a peek at their springs and check? That would be much appreciated.
It would be helpful if more recent owners helped to update the table in this thread, its a useful resource..
Cheers!
I got an update on this from Lynn. The springs are all the same height world wide, just different rates according to the spec.
Just checked. I am a Fieldmaster with the Rough pack, and the Electrical. No winch or Tow from factory but I have added both as well as sliders. US Petrol. I will be adding a rack and I will be towing about 3000 pounds off road.
Front Double green Circle
Rear Double Green Triangle.
This table is helpful.
I am still lost as to what to do. I measured from bottom of rim and the fender and i am 31” front and 32.5” rear. Just dropped it off for winch install which will add 70 pounds to front. I will also do a top bar at some point. When i pick it up tomorrow i can measure it again.
If i need springs can i just add some combination of lift which corrects my front sag but not really sure what to do in the rear since i want to keep the rake. My towing is only 10% of use at about 400 pounds on the hitch. I wonder if the small 1.7 lift and a metal cloak spacer in the back would be enough.
The problem with the HD spring is that even Eibach says on the website it is best to use under load.
This is an element of aftermarket addition of winch and bull bar i had not considered. Coming from Landrover world the airbags just auto adjust. Which i suppose is one answer for the rear. Airbags and some slightly beefier spring in front.
Are we ALL over thinking this?
I don't know if you can overthink this stuff but coming from a long engineering background of course I would say that 🤓 You could throw on a lift kit with beefy springs but it'll be a rough ride with compromised handling when it's not loaded up. There's also the front driveshaft angle and increased vehicle roof height to think about.
Here's my suggested approach to achieve this in a managed way without doing a HD lift kit.
  • Before you do any/more mods get your vehicle weighed, including the front and rear axle weights. Clean out the vehicle but fill the fuel tank.
  • Do any planned mods that will grossly impact weight, like winch, roof rack, bar work, etc.
  • Load up the vehicle to your typical trip weight. Fill the fuel tank then weigh the vehicle again.
  • Do the math for the total weight increase and front/rear axle loads (see below).
  • Select and fit the new springs (also below).
  • Add rear load assist airbags for towing to offset the hitch downforce (you know where to look).
Robert Pepper did a deep dive into 4WD payloads using the Grenadier as an example here. Note that he is using Australian weight and load limits which might be different to other markets.
Spring Selection.
Look at the symbols on your current installed springs. Look up their kg weight rating in the table then select a new spring part number based on the weight gain and split. Check with your dealer what springs are available. This may still force you to go aftermarket but keep an eye on the spring length. The springs in the IA table are different load ratings to match the build weight based on the vehicle but they're not a lift spring or a HD spring.
Axle Loads.
Winch weight can reasonably be assigned to the front axle.
Rack weight and loads could be split 40% front axle and 60% rear but you need to think about what you carry on the rack and where it is located and adjust the splits accordingly. 40/60 could easily be 30/70. Weight acts downwards through the centre of gravity which shifts forwards during braking so if you must carry heavy loads on a roof rack (not recommended) then increase the weight assigned to the front.
Adding weight must be done within the overall weight limit of the vehicle and the axles. These limits vary depending on the distribution market and local regulations. Some markets do allow for an increase in axle load limits via a process.
Hitch Downforce.
This is less straightforward because it also moves some front axle weight to the rear axle because the towball is behind the rear axle. Towball downforce increases when towing downhill and during braking because the trailer pitches forward and leans on the towball. If you only tow occasionally I would do a front and rear spring upgrade based on weight gain and axle split then add airbags to manage towball downforce and rear suspension sag.
Opinion only. This is not a textbook.
