Check your NATO plug
marcusnilsson
10:00 AM
Sweden
Hi!
I would recommend you all to check if your NATO plug opens or is stuck. Mine was stuck. Myself, a car workshop and my local Ineos dealer all tried to open it and failed.
The dealer reported the issue to Ineos and they agreed it needed changing. They had to create the articles for the spare parts as they did not exist yet.
Anyways, now it’s changed and works again.
I should add that I found the same problem on 4 other Grenadiers.
I should also add that the same issue happened with the lockable spare wheel box which needed to have the lock replaced.
My feeling is that this is a problem due to corrosion from salt but who knows.
Mine continues to get stuck. I'll smear copious amounts of grease onto the threads this time.
Hi!
My lid was smooth-running right from the start. My dealer checked every little detail before delivery. Even this lid.
Hi!
I have to use the same trick (pliers) to be able to open it. There was water inside my NATO plug and oxidation. I already mentioned that on the forum in the past.
My dealer told me they would replace it, but didn't.
I don't use the NATO plug, but the same power circuit cables are used for the front winch.
Therefore, water in the NATO plug = short circuit = winch not working!
I check it always before travelling!
Mine was a touch tight when I first picked up the car. I sprayed the threads with silicone spray ( not anything greasy , as that will attract grit) and put a little dab of paint over the thread starting point (a guide to the mating halves) so as not to damage the relative soft alloy threads.
Its bare aluminium and oxidises quite quickly, I regularly lubricate mine and its fine but I can see it would gum up quickly if left unused.
mines fine but
Yep. I looked closely and its some crappy cut threads in soft Al, that was leaving specks in the cap. one salty winter and that will be fucked. Some Noalox or antisieze is in order.
I would imagine that in the military there's some kind of rigorous maintenance regime. Either that or they were all designed by a Russian saboteur.
Maybe the buyer found a low cost supplier on Wish.
Although I was brought up to use an anti seize compound, such as Copperslip, on wheel studs. (child of the 60's), Modern thinking is this should not be done. Applying any form of anti seize compound can lead to over torquing of studs.
That said, for the many years I did use Copperslip I never damaged a wheel stud.
Mine was also siezed on delivery. Channel lock pliers got it open, and a cap full of water came out. Cleaned up threads, and copper ease. Has been severl months, so will have to check again.
I managed to get my cap off - just. It almost seized. Seems like Red Centre dust and threads are not that compatible.
Just don’t use copper slip on aluminium ! Or the aluminium will be eaten away
For studs like wheel studs I can recommend "Molykote 1000". It is not only an anti-seize medium it also equals the friction coefficient which helps to get the torque right. Even more important than the correct torque is equal torque among all studs.
AWo
AWo
Never heard of that product, so I looked at its Safety Data Sheet (AU). It is pretty nasty stuff especially for aquatic life, but I would not want it on my hands, when I can use Tef-Gel instead.
