Check Engine Light - “Stop Transmission Error”
12:59 AM
Indianapolis, IN, USA
Just went through a car wash and now have the check engine light on and the transmission error message that keeps popping up. Any idea how to resolve this?
Did the car wash spray water from below to the underside of the car? I assume soemthing got wet which shouldn't? maybe a plug, creating some kind of short cut or some kind of leakage current.
If you can drive, maybe it disappears when it has become dry.
Yes, it finally disappeared. I think it just needed time to dry out . I would have avoided all this trouble by engaging the wash mode.
I get the Engine error with all kinds of messages popping up every time I re-start the vehicle after refueling, if I'm sitting inside with the seatbelt on! If I remove the seatbelt, open and shut the door again once the re-fueling is over, the error does not appear (most of the time).
