Brake Controller Trigger Wire?
cdsvt
1:37 PM
Vermont, USA
I've read tons of threads here and the violet/orange wire in the trailer controller bundle under the second row passenger seat seems to have been unreliable. Is anything better with the most recent software updates?
Fwiw, I took delivery in July 2025 with the latest software updates.
I'm working on installing a Redarc TowPro Elite (which I've done on several other vehicles- all Toyotas), and found a super useful thread for all wires except the brake signal (Redarc blue) wire.
Redarc wire color - purpose - Vehicle wire color
black - 12v constant - yellow/red
white - ground - black
blue - control - grey
red - signal - violet/orange
Any up to date guidance would be greatly appreciated!
Thanks.
You will need some US input, because I believe the REDARC is wired slightly different in the US to Australia.
This is the thread I used to install mine
I used that link but the trigger wire isn't ideal. It is an option, but if Ineos fixed the software driving the factory brake trigger wire that would be a cleaner solution.
Only relevant IF they fix. Could be either a software or hardware issue. Hard to tell….. The running of a line to the actual wire, and using the diode, is the best bet for now. Betting on waiting isn’t worth it IMHO.
That is what I'm trying to ask: DID they fix the brake signal reliability in the violet/orange wire in the latest software update?
I haven't seen anything that said they did in the update notes. Try asking a dealer?
Dealer went over release notes for my 24.1 update and was not present.
I honestly do not think this is software….
I ordered the Redarc diode.
This vehicle is delivered like a not quite finished project. There's always something more to buy to fix some deficiency that Ineos left for the consumer to deal with.
So I've wired the redarc control box in as described in the linked thread:
Can anyone tell me what color wire I can find in the rear quarterpanel that is attached to that grey wire? I don't see a grey wire in the bundle to the TCM plug. I need to wire whatever wire this is in to the blue wire on my 7 pin trailer plug. Alternatively, I could run a wire directly from the redarc harness to the 7 pin trailer plug, but I'd rather use the existing wiring if possible.
Does anyone have a handy brake signal wire that I can also use? I need a wire that tells me that the brakes have been applied. This will go to the red wire (via the Redarc diode) on the Redarc brake controller.
This is a US delivery 2024 grenadier.
Blue/Orange or violet orange looking one. I tapped in circle area. It is the brown wire you see to the left next to speaker wire, I used to run under batter tray.I had 2 that looked nearly identical. I used a light meter to test when brake pedal was depressed, and light went on= use that line.
Diode in next pic.
I was overthinking the diode. The center terminal (terminal 2 - orange wire) is the trigged signal from your brake lights, and the two outer terminals (terminals 1 and 3 - red wires) are out. You can use either one you want to go to the Towpro red trigger wire. The other is not needed for this configuration, so you can cap it with some shrink wrap to avoid it shorting out.
For anyone even less familiar with electronic diagrams than me, the diode only allows electrickery to flow in one direction. The pointer of the triangle on the diode schematic shows the direction of one way flow. In via pin 2 and out via 1 and 3. Practically speaking, it prevents 12v+ power from back-feeding to the vehicle brake circuit.
pin
Diode in next pic.
I wanted to close the loop. I was able to use the blue sheathed wire with orange tracer as you said.
Thank you!
This wire with the pin backprobing it (connector that goes to the factory trailer brake module in vehicles equipped with that feature):
First: Thanks for these great posts on the redarc trailer controller install.
I would like clarification on the following detail.
The wire that was tapped to connect to the diode, is that accessed under the seat, or do I need to get access to rear panel where the TRM is located?
Basically, can I do this all from under the rear seat, or do I need to remove the rear panel? My vehicle is a 2025 Quartermaster, but I assume the TRM is more or less in the same general area as it is on the station wagon.
I am trying to determine if this photo, shared earlier in the thread is under the rear seat, or in the rear panel?
I do not have the vehicle in front of me at the moment or I could take a look,
Thanks
Thanks
That photo is 100% in the rear cargo area wall on the us passenger side behind the quarterpanel.
I installed the Redarc diode under the second row seat. I ran a wire from the rear quarterpanel to the second row area. This puts it closer to my Redarc brake controller.
FYI - I didn't run a wire, I went with the IG recommendation- the module/software isn't sending the signal from pin 9 to pin 2. I spliced in the diode into the pin 9 wire and then wired the wire coming out of pin 2 also to out on the diode. This activates the brake signal wire in the loom under the seat.
Thanks
@TomHanlon
Quartermaster TRM is on the back wall of the cabin.
I have a quartermaster. I'm also installing a REDARC tow pro elite. It appears the back seats need to come out to get to the TRM. I tested my control wire under the seat.....nothing. Irritating! BTW, I dont understand the nature of the signal. If the signal is just 0 or 12 volts, what information determines how much brake is applied?
