Body Color
Stu_Barnes
Fixer & General Dogsbody
4:31 PM
Los Angeles
Solid White
Solid White
Stu_Barnes
4:31 PM
Los Angeles
Solid Mushroom
Solid Mushroom
Stu_Barnes
4:31 PM
Los Angeles
Solid Light Blue
Solid Light Blue
Stu_Barnes
4:31 PM
Los Angeles
Metallic Light Blue
Metallic Light Blue
Stu_Barnes
4:31 PM
Los Angeles
Solid Dark Blue
Solid Dark Blue
Stu_Barnes
4:31 PM
Los Angeles
Solid Green
Solid Green
Stu_Barnes
4:31 PM
Los Angeles
Metallic Red
Metallic Red
Stu_Barnes
4:31 PM
Los Angeles
Solid Black
Solid Black
Stu_Barnes
4:31 PM
Los Angeles
Metallic Black
Metallic Black
Stu_Barnes
4:31 PM
Los Angeles
Metallic Gun Metal Grey
Stu_Barnes
4:31 PM
Los Angeles
Metallic Silver
Metallic Silver
Ovrland Bill
4:31 PM
Thank you, Stu, for all your work to post these color images, I only wish I had more faith in the ability of my humble iPad to faithfully render them! Short of being able to see Grenadiers in the flesh, I look forward to seeing high quality photo prints of these colors (in a magazine?). Bill
Elson
6:31 PM
Great post, will be interesting to see if they do any special 'launch' colours. Appreciate that there's a way to go yet, but I'd love to see a burnt orange colour. In the meantime I'm a huge fan of the shade of red.
I also wonder if they'll do any factory style wraps like LR have done with the new Defender. Not a huge deal if not, but still curious!
Spjnr
12:31 AM
Essex
The solid green seems to have a blueish tinge to it, almost like a blue spruce. This matches up with 2B126 thats been seen sporting a very similar shade of green. If so that's the exact green I'd be looking for!
Red pepper
9:31 AM
Australia, Qld, Gold Coast
Looks like the INEOS updated the car builder and included a red or orange paint option for the nose and back door.
Stu_Barnes
4:31 PM
Los Angeles
It’ll ba a bit of a marmite option I think, but I want it.
“If something is described as marmite, then there's no way you can be indifferent about it or express minor shades of like or dislike. No, if it's marmite, then its very nature forces you to firmly sit in either the 'love it' or 'hate it' camp.”
Stu_Barnes
4:31 PM
Los Angeles
The red and orange nose and back door paint option is limited to:-
Solid White
Solid Mushroom
Solid Dark Blue
Solid Black
Metallic Black
Metallic Silver
If you select a contrasting rear door color then you can only have a body colored roof.
Contrasting rear door is only available if you select a contrasting nose.
These paint colors do not have the contrast nose and rear door paint option:-
Solid Light Blue
Metallic Light Blue
Solid Green
Metallic Red
*this is for the North American market configurator, if any other options are available in the rest of the world please update this thread for the community.
grenadierguy
5:31 PM
Colorado
@Stu_Barnes thanks for putting together the list!
I'd like to see additional contrast noses. Like on the light blue or mushroom, white or Black nose to match a roof color change. Why, not you know?!
12:31 AM
Of course, the appeal of any given color is subjective, but to my eye, a lot of these colors look great! Thanks @Stu_Barnes for posting all these images!
Just FYI comparing solid to metallic paint:
Solid paintThe vast majority of cars come with a ‘solid’ paint finish as standard. Most manufacturers offer only a limited selection of solid hues – typically white, red, blue and black. But even in that range, there’s usually a wide variety of shades to choose from. So, whether you want your car to disappear into the background or stand out from the crowd, you should be able to find an appropriate color without shelling out extra money.Solid finishes are free because they’re simple to produce. There are usually only three layers: primer, paint and lacquer. Many manufacturers now use a paint known as ‘two-pack’, which is simply the paint and lacquer mixed together.Repairing solid paint is easy: small stone chips can simply be filled in with a touch-up pen in the appropriate shade. Any car spares shop can supply the right pen for not much money. More significant repairs are comparatively easy, too, as the paint dries out quickly with the aid of a simple heat lamp. You could even do it at home, as the necessary equipment is inexpensive and an even finish is easy to achieve.You still need to be careful, though, to avoid the dreaded ‘orange peel’. This occurs when the layers separate, usually because moisture got in while they were being applied.They may not be the most interesting, but solid paint finishes are certainly the cheapest and easiest to look after. Metallic finishesMetallic paints reflect light for a much brighter shine than solids. They come in a wider variety of colors and add relatively little to the cost of the car – from around $750 on small cars.The shine comes from a small amount of aluminum powder mixed into the paint. The metal particles pick up and reflect light, hence the shine. Multiple layers of paint and lacquer – which largely account for the extra cost – add to the effect.Metallics look their best under direct, natural light, but even on a dull day they still shine.Dirt shows more obviously on metallic finishes than solids, so you may end up cleaning your car more often. Be careful, though, as the paint marks more easily. Use a proper car shampoo – washing up liquid contains abrasive salts – and make sure there’s no grit on the sponge. Over-zealous polishing causes swirl marks and car wash brushes can leave marks, too. But any marks can usually be carefully buffed out.Metallic paint is more difficult to repair, as achieving an exact match is tricky. Even manufacturer-approved body shops don’t make any guarantees.They add cost and need more care, but metallic finishes add significantly to the visual appeal of a car and often boost its used value.
Source:  https://www.carwow.co.uk/guides/glossary/car-paint-types-guide
Spjnr
12:31 AM
Essex
Anyone else notice Metallic black is no longer on the configurator? wonder if its a glitch or whether its been dropped?
