Blind spot mirror
hoohoohama
7:54 AM
New York
Anyone planning to attach blind spot mirrors? There is a rather large blind spot on the driver side, wondering if anyone is planning to install aftermarket blind spot monitors or just stick a blind spot mirror?
Hi hoohoohama, I have attached round 2" blind spot mirrors on both drivers and passenger side mirrors for years and find them invaluable. They have kept me from making many ill-timed lane changes and perhaps a couple accidents. They take a little while to get used too, however after using them for years, I cannot go without them.
I personally like to mount them along the bottom as far out on the mirror as I can as that allows me to catch more vehicles in my blind spot. They typically come with and attach with double sided tape. It you ever need to remove them, just get some fishing line and work it back and forth behind the mirror and then clean up any residue with thinner or perhaps acetone. Just don't get any thinner or acetone on any plastics. DaBull
I find that, if I adjust the left outside mirror “outwards” (away from the driver), I can all but eliminate a ‘blind spot’ to the left of the vehicle (left hand drive cars). Also, if I then lean my head further to the left I can begin to see at least part of cars directly behind the Grenadier. Are these the blind spots you are referring to?
The reason I use the 2" round convex mirror is to catch cars that are just behind the B pillar that sometimes are not visible in the normal mirror.
It's amazing how a large car or small motorcycle can be right next to you and you cannot see it. They are just a few dollars at most auto supply stores and on the web.
I recommend buying a pair and just using some scotch tape double up at the back of the mirror to temporarily put them on the mirror in order to see how you like them and where you like them best. Don't take them on too long of a test drive or they might pop off until you use the double sided auto foam tape that is already attached to the back.
I highly recommend them. DaBull
Yes, but the blind spot is bigger than you describe. I have my mirror set similar to you, and it runs out of range (actually hits the plastic frame) before I can set it where I would like.
Thank you all for your inputs, perhaps it depends on my seating position, I do feel there is a rather large blind spot and I had to lean forward quite a bit to avoid the b-pillar. Will try out those convex mirrors as suggested by @DaBull. Thanks again for all the detailed information.
Maybe we can get this company to make one for our Grens.
Sent them an email asking if they have plans for the Gren. Really would like an integrated solution.
I like a slightly convex mirror on the passenger side mirror. Pretty much what the linked company above is giving you. No need on the driver's side. Turning my head to check is so ingrained into my neurons I'll be doing it when they lower me down.
A poor photo as it is wet and dark outside, one particular slip lane is very blind due to the angle, this helps and was just £3.99 for two on Amazon! Beeway Blind Spot Mirrors
Same as mine, I am in the UK, RHD!
It must be my height (5' 6") and seat settings, but I don't have any issue with the door mirror. Albeit it is a its closest to the door position so I can see why anybody taller than me ( that's everybody) would struggle
The first blind spot mirror worked poorly, so I removed it.
I ordered and installed a 2 inch Ampper Blind Spot Mirror. It uses 3M tape. The new mirrors seem to be working much better and the design allows you to alter the angle of the mirror. It is available on Amazon US and AU.
Ampper do make some larger mirrors if the 2 inch model does not work out.
Links are too Amazon AU, not Amazon US.
In use the same one on my driver side mirror.
I have never suffered with this blind spot issue, however I put this down to a special tool I have called a neck ! I tend to use it to rotate my head and do shoulder checks. 👍 😃
I also used this tool in the past. I should still have it hanging around somewhere.
If you are or have been a motorbike rider, it is still something you do as a matter of course
