Marty is the exclusive distributor for the US!
Nah I will just press harderFor those that don't want to go the full hog of a tune. I can highly recommend a Throttle Commander. Several of them out there for the Grenadier. They don't increase power, merely make the throttle more responsive. No insurance issues to deal with and for the money, a great addition, in my view.
Fill yer boots.Nah I will just press harder
Marty talked me through my installation at the end as the cam sensor was a little tricky for me to locate.Loving My Bluespark - I have 2000 miles on mine now and it works great. Gas mileage per gallon depending on how you drive, but mine is at about 14mpg.
Call Off Road Gear Guys - Marty to purchase yours here in the US>
Yeah it can be dialed in. They say they’ve figured out the best all around tune from the factory so not to change the setting it comes with. That’s unless you have added weight or big tires and height etc. That would require the setting to be a bit different than a stock set up.Can this also be put in eco mode? If so, what is the increase in mpg?
How much is this thing, when buying from Marty?
So do you NOT recommend buying the TDI tuning software for increasing your mpg on your INEOS ?There is no way this thing is getting 18mpg. The closest I got was 16.5mpg and that was at very high altitude and babying it. The MPG on the dash isn't legit it's using Imperial gallons which is 20% more.
You mean with the tuner? Or just stock?If I drive conservatively, I will easily get 18 to 20 mpg. Depends on how conservative I wish to be, and how often I use cruise control.
How are you doing Flying Texan, I’m a new Grenedier member in California and I saw your results from the Blu Spark. So did you have to do any other modifications with that? And did you have to use special fuel? Or was it just on 91 octane snd the blue spark?As an update the BlueSpark has made it awesome. I can really feel it launch and hear the turbo going as it's shifting through gears. I love it and I'm glad I did it. I left it at it's default of 430HP, I haven't done a dyno with it but I find myself punching it every time I get in because I just like feeling it dig down and go. Absolute night and day difference. No fuel numbers as of yet. Haven't had a long road trip to measure.
I use a chipyourcar.com tuner chip. Whenever I take my vehicle to the dealer, they remove the chip from the ODB2 port for their diagnostics and put the module back after. The service team doesn't comment about it.I read that bmw systems have a way to flag out of spec engine metrics. So in the event you use these piggyback tuners, the dealer + manufacturer can “infer” such device was used..
Anyone experienced with this area?
