Auxiliary battery
In
Kept closed in a climate controlled lab at 25C. 😉 It'd be at least double that in the field in summer.
Well I won’t argue the actual numbers because I don’t have a proof point. However I do know that in my previous vehicle with an an Optima yellow top deep cycle battery well under 105Ah I could run my Bushman for about 2 days in hot temperatures fairly easily. I really don’t expect much more than that from any dual battery system without running the car or topping up with solar. Depends of course what else you are running but I don’t run an inverter or induction hotplates or appliances etc when I am camping. I do sometimes run some low draw led lights but usually they run from my camper battery
Does the IG come with an Anderson plug somewhere externally?
I don’t tow, but really liked having this on the old 110 with my dual battery setup as it allowed me to make a long extension lead and run it to tents etc., and also this is where I would connect a battery charger too when parked up in the garage for a while.
No Anderson plugs.... it will need to be a DIY mod.
Depending in your spec it has a NATO style plug on the back and I have made up an adapter to Anderson, however apparently it isn’t live all the time. Rumours that a software change may fix but otherwise may need to bypass the relay to make it permanently live.
Thanks. Trialmaster, so I believe that’s all the internal electrical toys/ options ticked? Not sure what a NATO plug is but not fussy about shape, only timing/flavour of the electricity supplied. Will keep an eye out for mods which enable 👍🏼
That is one.. certified for 12V or 24v and up to 1000A. Grenadier specified afaik (not verified). 12V 400A
Lead acid batteries of course have a cycle life depending on how deeply discharged they are. You often read caravaners saying 'I get 3 - 4 days no problem' but the batteries are being discharged to 10.5-11.0V. If regularly taken below 12.2V (50%) you reduce cycle life by about two thirds and you're replacing batteries every few years. Optimal cycle life is staying above 70% state of charge but typically not practical so 50% is a good compromise. A good system should be designed around that.
