- Local time
- 6:36 PM
- Joined
- Sep 4, 2022
- Messages
- 76
Has anybody found aux outlets in footwells,under bonnet and fusebox.Had a quick look but cant see anything obvious.Do you have to remove covers.Quick start guide very vague not a good picture.
drive.google.com
Would you know, by any chance, which fuse corresponds with EXT 1?The compressor installation is now complete.
I also attached a work light to the rear ladder. I can switch all the lamps and the compressor separately.
EXT 2 : work light on the right
EXT 3: work light on the left
EXT 5: rear work lights
EXT 1: compressor
Next job will be installing a mirror dash cam with another camera on the back door.
The fuse placard for "The Interior Electrical Centre" has just a single entry for "Overhead Console Switch" F128. As to which switch it refers is another question. However, if you remove F128, you'll soon determine whether or not switch Ext1 is "live"...Would you know, by any chance, which fuse corresponds with EXT 1?
Would you kThis is my layout for the compressor. EXT 1 only controls an extra relay. Therefore it doesn't matter that the switch is only fused with 10 A. The compressor itself is protected with an extra automatic 50A fuse.now, by any chance, which fuse corresponds with EXT 1?
This is my layout for the compressor. EXT 1 only controls an extra relay. Therefore it doesn't matter that the switch is only fused with 10 A. The compressor itself is protected with an extra automatic 50A fuse.Would you know, by any chance, which fuse corresponds with EXT 1?
As far as I can see from the manual, and the efforts of others to document the unlisted “auxiliary” fuse/relay box for the roof and under bonnet 25A point, the only fuse I can’t find documented is EXT 1. I was just wondering if you had discovered it during your compressor install project.This is my layout for the compressor. EXT 1 only controls an extra relay. Therefore it doesn't matter that the switch is only fused with 10 A. The compressor itself is protected with an extra automatic 50A fuse.
I can’t quite get to the taped EXT 1 wires without loosening the filter housing. I’ll finish off a few other projects before playing with that.The fuse placard for "The Interior Electrical Centre" has just a single entry for "Overhead Console Switch" F128. As to which switch it refers is another question. However, if you remove F128, you'll soon determine whether or not switch Ext1 is "live"...
Unless perhaps a single fuse controls power to operate several relays controlling the other switches respectively...in which case pulling the fuse might render all switches inoperative....I hardly think this is likely but it might be worth exploring...
Can you test and let us know?
You have found the three wires for the air compressor (that I believe was part of the original design concept, but not fitted in production). The Brown wire is fused at F113 (40 amp) and is permanently live. The Yellow wire is live with the ignition (not by any of the fitted overhead switches) and can be used to power a relay for a compressor.Bonjour,
J'ai découvert une alimentation électrique en attente, dans le coffre sous le siège arrière droit à côté de la batterie Auxiliaire.
L'alimentation comporte trois fils
La masse en noir
Le + 12 volts en marron (avec un gros fil pour 25 A)
Un fil jaune de plus faible diamètre.
J'ai installé un domino et à ma grande surprise, moteur éteint et interrupteur PRW sur Off, cette sortie est alimentée en permamence par la batterie PRINCIPALE (12,5 Volts sur la batterie principale et 12,93 Volts sur la batterie auxiliaire).
Cette sortie ne semble pas documentée sur le guide de poche.
Plusieurs questions :
Quelle est la fonction prévue pour cette alimentation ?
A quoi sert le fil jaune ?
Existe-t-il un interrupteur pour couper cette alimentation ?
Peux-t-on la modifier pour la faire alimenter par la batterie secondaire ?
Merci pour vos retours
Thank's a lot for your return
Merci beaucoup pour votre réponse. C'est effectivement beaucoup plus clair. Le fil jaune sert donc à commander un relais lorsque le contact est mis et que le moteur tourne, De cette façon il est possible d'alimenter un compresseur en sécurité.Vous avez trouvé les trois fils pour le compresseur d'air (qui, je crois, faisaient partie du concept de conception original, mais qui n'ont pas été installés en production). Le fil marron est fusionné à F113 (40 ampères) et est sous tension en permanence. Le fil jaune est sous tension avec le contact (et non avec aucun des interrupteurs aériens installés) et peut être utilisé pour alimenter un relais pour un compresseur.
Super, mais vu la langue, est-ce qu'il ne vaudrait pas mieux mettre ces informations dans le forum en langue française ?Bonsoir à tous.
La sortie électrique 12 Volts sous le capot est commandée par l'interrupteur EXT1 au tableau électrique de commande supérieur.
La présence de cette sortie 12 V dans le compartiment moteur, peut permettre d'alimenter directement des phares additionnels à LED par exemple, ou des feux antibrouillard. L'allumage des feux nécessite d'activer la commande EXT1 (et de penser à l'éteindre en quittant la voiture ...).
Une autre solution consiste à assurer la commande d'éclairage à l'aide d'un relais. La commande du relais est assurée par un branchement sur le fil d'alimentation des feux de route par exemple.
Ainsi, en activant les feux de route, le relais est activé et si l'interrupteur EXT1 est sur ON, les feux additionnels sont allumés. Si l'interrupteur EXT1 est sur OFF, le relais n'est plus alimenté et les phares additionnels ne s'allument pas. Cette disposition permet de se conformer à la réglementation en vigueur qui interdit les feux additionnels en usage routier.
I will have to deceive you, I don't know ...@Jean Mercier
Where did you get the "black tie bracket" below so you could attach the Deutsche plug to the wiring? See the red arrow you put on the image. Thanks. Does it have a name?
