- Local time
- 4:13 PM
- Joined
- Aug 23, 2022
- Messages
- 1,037
- Reaction score
- 2,243
- Location
- Rhine - Main Area / Germany
Hm, there are always certain situations where things can go wrong. .. And as you mention the topic of Diesel Filters.. these pieces are like computers.. introduce problems we never had without it. - That is why older and simpler built vehicles survive in Africa and stay reliable. Because of simplicity. The LED topic is another. of course is a failing LED shit in the middle of nowhere. However if a LED fails at all. In the meantime there exist LED in form of a classic lightbulb. And once again - the very same problem regulatory.Understand, but every car ist tested in hot and cold climates and in all aspects. Nevertheless they still have problems, here and there. Testing doesn't mean solved. It can lead to a complete solution, a partial soution (to set the limits closer) or to even to none solution (if it is acceptable for most situations). And if you keep in mind, that the Grenadier is pushed out with a lot of force which even led to cars getting repaired at the dealer, I doubt that each and every problem was addressed. And a gearbox is nothing, where problems always get fixed quick and easy. The cooler will help, that's for sure. But I'm not after these fine videos with Grenadiers driving in a chain over tracks at a good speed through Morocoo, I'm referring to slow drives through sand dune fields for an extended period of times. We saw 4x4s with diesel particle filters where the engine went into the emergency mode, because a filter cleaning wasn't possible while a lot of exhaust gas was produced at the same time (engines needs to run for a certain amount of time at a certain speed to start the filter cleanin program. In some countries you can do that while the car is stationary, but not everywhere). Different thing, I know, but these cars have also been tested in hot climate but that issue was either accepted or not known. The three guys from Grand Tour tested the new Discovery with Limited Slip Clutches in the rear axle. If you drive often enough in small circles you get the clutches that they heat up and close 100% (to have no friction and cool down). While that is fine for loose ground, the next step ist to open them 100% if they do not cool down enough. That is not what you want in bad terrain. Also another example of something which was tested, build but still has drawbacks. BTW, in the German part of this forum a guy reports that his transfer box was tested at a French dealer by Ineos technicians and found OK. So it seems that at least a few problem boxes might pop up...tested or not.
The funny thing is....if we talk about LED light fo example, fear is expressed over and over again that one light could fail in the deep of Africa, at night, in hazardous environment and that is an absolute no-go to use these LED-lights! But when you talk about another scenario which might even be worse than that (a broken gearbox or a stuck car) it is claimed that these are only extreme situations, which one will never will be exposed to....
AWo
Back to tremec transfer case. - Yes indeed there might be the topic of overheating in a few rare operational conditions. Okay I understand your position I am myself in most cases the Devil's Advocate.. and Murphys Law.. but also - the more optimistic part.. this was developed by Magna.. they should know what they re doing. What brings me to a question.. How is this problem resolved in a Mercedes G transfer case ? - This is not the first project of its kind.
