AUSTRALIA: Third Party Suppliers for the INEOS Grenadier and QM
Rest day in Darwin before I go remote early tomorrow. I re-organsied the first part of the links (still a work in progress), but now time to go exploring and adjust to the humidity.
PLACE TO START FOR NEW OWNERS
  1. Download and use the Rok Dr Guide here. Print out a copy and keep it in the car;
  2. Grenadier Accessories (huge selection) for you to buy here;
  3. Kanvas bags and products here (Australian focus). Part 1 sorted by company names here, Part 2 sorted by name here. Part 3 the links are sorted by subject and includes Carpet Grabbers, Firewood carriers, Molle Bags and Rear Wheel Bags (for gear or garbage) here;
  4. BATTERY MONITOR: Cheap battery monitors here;
  5. BOLTS&SCREWS: Grenadier Screw/Bolt head types & sizes thread here including downloadable Table here. Also summary Table in Rok Dr Guide at paragraph 9.9 and Table 14 (Fastener Types);
  6. BOLTS&SCREWS: Various recommended torque settings here and here (with Torque Table). General torque values (not INEOS specific) here. This point overlaps with the previous one;
  7. BOLTS&SCREWS: What are owners using on bolts/screws to stop corrosion, galling and seizing? Look here;
  8. CRIMPING: Guide to terminal crimping here;
  9. CRIMPING: Anderson plug pitfalls here;
  10. ELECTRICS/AUX POWER OUTLETS: Finding the aux power outlets in the footwells here;
  11. ELECTRICS/BUSBARS: Littelfuse FHZ busbars used in the Grenadier here. It also informs you where all the busbar cables go;
  12. ELECTRICS/CABLE SIZING: Copper Cable sizing chart and Conversion Table here (if you want to work out what cable to use to power accessories), or download a PDF from BLUE SEA Systems here or use their Circuit Calculator Wizard here;
  13. ELECTRICS/CHARGERS: Understanding battery chargers and how to use them (they do more than any alternator) here;
  14. ELECTRICS/CTEK: Learn more about the CTEK SMARTPASS 120S and 250SE here;
  15. ELECTRICS/DEUTSCH PLUGS: Information concerning Deutsch DTP plugs here;
  16. ELECTRICS/FUSE&RELAYS: Fuse and relay thread here;
  17. ELECTRICS/FUSE&RELAYS: Suggested Grenadier or QM fuses spares kit here;
  18. ELECTRICS/GENERAL: A break down on how power is used, in the Grenadier/QM, while camping/opening doors here;
  19. ELECTRICS/NATO PLUG: Understanding the NATO plug on the Grenadier here and why you need to check your NATO plug here;
  20. ELECTRICS/WIRE ENDS: Table describing all the available wire ends here and here (you have wire ends if you selected the high aux power option);
  21. ELECTRICS/WIRE ENDS: Having trouble finding EXT 1 and EXT 5 wire ends under the bonnet/hood? Start at this post and read on;
  22. ENGINE: B58 Petrol Engine Reference Manual here and here;
  23. ENGINE: B57 Diesel Engine Reference Manual here and here;
  24. ENGINE/CAR SERVICING: Servicing schedule for the Diesel models here and Petrol models here. Both schedules are also in Appendix 5 of the Rok Dr Guide;
  25. ENGINE/CAR SERVICING: Grenadier Fluid Specifications PDF download here;
  26. ENGINE/DFP: What is helicopter mode (DPF regeneration)? The sound diesel models make when there is a DPF regeneration underway (burnoff), as the thermo fans spin at high speeds. The fans can be very loud when the car is parked and the engine off, hence my nickname "helicopter mode";
  27. ENGINE/OIL: Oil Change Procedure & Specs here;
  28. ENGINE/OIL: Oil filter part numbers and third party filters here;
  29. FILTERS: INEOS Air filter parts numbers and cabin filter here;
  30. FILTERS: Filter for Diesel/water separator here;. Only installed on some diesel models, standard in Australia and South Africa and optional in other countries;
  31. FILTERS: Information on the Hengst oil vapour/air separator installed on the Diesel models here and here;
  32. KEY FOB/REMOTE: How to open the Key Fob/Car Remote look here. The battery used is a CR2032;
  33. L TRACK: L track information here;
  34. L TRACK: Quick Release ties downs for your L track here;
  35. RECOVERY: If using a bridle or equaliser strap in any recovery, please watch this video first;
  36. SUSPENSION: Considering airbags for your suspension? Thread here and Australian sellers here under the heading AIRBAG SUSPENSION.
  37. TOOLS: Tool kits for the Grenadier/QM discussed here and here;
  38. WIPERS: Want better wipers? Try the WiperTech for your INEOS Grenadier or QM (AU link here); and
  39. Outback driving tips here.
BULLO RIVER STATION UPDATE
There was rain overnight at Bullo River Station, so planes cannot land on the unsealed air strip. Guests are leaving earlier from Darwin and being taken to a nearby air strip – that would be a country “nearby”. Kununurra has the nearest sealed strip.
Then Guests have a 3 hour drive into Bullo River Station, which has the longest driveway in the Northern Territory. The driveway is the hard left off the Victoria Highway on the map below. It is all part of the adventure (it seems I am already back in adventure mode!) Plus I now I know how to drive the Grenadier into Bullo River Station!
I now miss breakfast due to the early start, but the Oaks Darwin gave me a takeaway solution instead.
Back from Bullo River Station after a hectic 4 days, but I am Darwin based for another week.
Amongst many events we had breakfast in Bullo River gorge, dropped off by a bush taxi (aka a Robinson R44 helicopter).
Corroboree Billabong
I visited Corroboree Billabong before in the Nissan Patrol days. A must see place to visit when in Darwin.
I hope to return to travelling in the Grenadier, once the injuries are sorted.
Yesterday I visited Corroboree Billabong again, on a day trip out of Darwin. It has the densest concentration of crocodiles in the world, both fresh and salt water. Corroboree is located on the Mary River floodplain.
At Corroboree we saw a croc close to 5 metres. More than capable of making a meal of the stupid or unwary. More images over at the blog post.
QM FILTER BRACKET
MORE4X4 has a fuel filter bracket for the QM Cab Chassis. As the QM Diesel (at least in AU) has a second fuel filter, this is for Petrol models. Bracket bolts on, no drilling required. I would not fit another fuel filter if you already have two fitted like AU diesels.
That bracket is fitted to a QM Cab Chassis, not sure if it works on the QM with a tub.
Description says more information is coming. So do some more research before buying, like calling MORE4X4.
That may be a tempting addition for QM Petrol models.
MORE4x4-ineosquartermasterauxliliaryfuelfilterauxbrackettracklanderroofrackmeshfendertopsoffroadanimaltorobullbarloopcheckeredplatealloy-31_1800x1800.jpg
Plenty of AU vendors having sales at the end of the financial year. Like Black Sheep AU.
BULLO RIVER STATION
Another blog post from the Bullo River trip. When we arrived down at the end, AWC served a cold breakfast on the river.
JMACX GVM UPGRADES PLUS MORE
JMACX GVM upgrades. QM will get a GVM Kit for 3.8, 4.2 and 4.495 tonnes.
Plus a cheaper suspension option, including a 2 inch lift (it seems for both the Grenadier and the QM, but not yet confirmed).
They briefly talk about the front shaft issue, but no discussion of their fix.
No talk about the front dampener JMACX are making.
View: https://youtu.be/IuT4X8R6bqQ
NEW ROOF RACK
New 3/4 length roof rack from Euro Flo Expedition. Ideal for those with safari windows and it has a very low profile.
NEW SINGLE AIR COMPRESSOR MOUNT IS COMING
A new air compressor mount is coming from Euro Flo Expedition. It goes where the jack is stored. Single ARB Air Compressor. I am reliably informed there is a coming Canny Outdoors video on the mounting bracket.
With a 50% jump in air flow with the new ARB brushless compressors, single compressors are becoming a more appealing option, if you do not require redundancy.
New heading
FENDER GUARDS/PLATES
Options include:
  1. INEOS OEM fender guards;
  2. MORE4X4 Australian made fender guards here;
  3. XSPEC Australian made fender and hood guards here;
  4. XLW fender guards (AU Agent) here; and
  5. ABNTR4X4 fender guards (AU Agent) here.
Bullo River station - full report written
Full report on the recent AWC Supporter's Event at Bullo River Station, with lots of information and pictures. Always great to visit a new remote location in Australia.
ROAD TRIP TO PICK UP THE VAN
I leave on Sunday for a road trip to pick up the Vista RV Crossover. Down to Melbourne, pick up the van, take it back to NSW, get it registered and then put it in storage.
Then back to Sydney for more medical appointments and no vacation trip in the van.
I will sleep in the van at least 2 nights as part of the trip. I should learn a few things along the way.
full
full
