Added Garage Opener to the Grenadier
I looked at this and there are a couple more, and for the price I was thinking use what I already have and only had to drill a round hole. lol But yeah that would be another great option too! There is one that I found that was single button but they wanted 229$ USD for it.
I have to say yours fits in perfectly with the aesthetic! And love the location.
Just did it. Thanks for the idea Tenac!
So you need to remove the overhead panel to replace the opener’s battery?
Yes, it is on an hinge the whole thing swings open if you just pull down on the rear section and work your way to the mirror. Super simple takes less than 3 seconds to pull down and let hang on the hinges.
Damn.. is there a video of this procedure?
Yes and No. I only need to remove the front panel (four screws) to get to the battery. I also left my circuit board inside the plastic case it came in, but without the push button mechanism…
Ahh the overhead panel comes off in pieces? I thought it was a single unit
Three panels. I chose the smallest panel towards the front because once removed, there is a small hole that I can pull the controller through to access the battery. There’s a nice little pocket up there for the controller sit in.
You can do it either way, I found just pulling it down and letting it hang on the hinge was easiest for my location. I placed button further back so the wife could reach it. I don't have a video but if you have a plastic body trim tool just work your way around the back in a U shape once you get it started it just comes down easy and swings on a pivot at the front by the mirror.
I’m adding a Homelink (the model below) and trying to figure out the best location for it. Seems like the location circled would work, but not sure if there’s anything behind it. Before I start pulling panels, anyone know?
I've seen other pics I believe you are good to go behind that panel. I'm not sure how much room for the Homelink box however.
Unfortunately there's a metal bracket behind that panel now that I look.
Oh is it up that high on the panel?? I know that seems to be where people are putting the Brake adjustment knob or in some cases I've seen some use it for After market radio knobs for selecting profiles etc....
There’s about 1/2” space between the parcel and the metal plate, so something shallow would work.
Well looks like I lied! I used my little scope camera to look behind the panel, I should have just removed it (a lot easier than I was expecting). There’s a plastic (not metal) plate / tab behind it. I just cut a notch out of it and it all fit fine.
