270 degree Foxwing awning with NO roof rack????
AlanJ
Production/Transit
12:50 AM
Sydney
Did a 5 hr each way road trip late January, also went mountain bike riding via appprox 5 kms each way of dirt roads etc etc over creeks and ruts and corrugations at speed, It has been nothing but rock solid.
skoller
10:50 AM
Yackandandah VIC, Australia
It all sounds like its the way to go but I might see if I can fit the 4 brackets thats in the kit just for extra support . Thats saved me a lot of trial and error because I only have 100mm above the roofline so it fits in the garage.
grnamin
9:50 AM
Texas, USA
Cool bike rack. Love the design!
AlanJ
Production/Transit
12:50 AM
Sydney
Its possible for sure, buy the 4 pack of base stow it brackets and then 2x packs of the awning brackets.
You will need the extra bolts that slide inside the back of the foxwing eg 2 sets to hold all 4 of the mounts.
Only thing will be how accurate you are with a tape measure as you need to line up all 4 ideally perfectly the first go, an extra pair of hands would help
For that part.
AlanJ
Production/Transit
12:50 AM
Sydney
Yeah the spare tire means these kind of racks probably make the most sense, especially for long trips. Short in town trips they can be a pain however…. But then again depending on how many bikes you have and the cost i will trade convenience for overbuilt stability and piece of mind. Here is a side on shot, its possible to adjust it and lower it all the way down with the bikes off to still fully access the boot.
Single tracks is the brand.
GGR
12:50 AM
australia
I was looking at doing something similar, and wanted to keep the profile as low as possible with an awning being attached, i am think normal 2.5x2.5m awning at this point.
A few questions:
  1. should the silver metal bar rotate? Only the side which i removed to put bracket on rotates easily (by hand) Should i be doing something up tighter? Need to add some rubber?
  2. Did your bracket rest on the gutter rail?
i think due to holes in bracket i will flip it so its the other way
AWo
4:50 PM
Don't go for the Fox Wing. Take its successor Bat Wing. It is much better.
AWo
pedrogb
12:50 AM
Townsville Australia
I'm pretty sure I can't attach mine to the rails. I just picked up a bargain from Expedition SLRV on the Gold Coast. Only problem it weighs 40kg. The brackets are for a platform rack, I have the three cross bars. The brackets that came with it weigh over 10kg, they are 6mm stainless plate, folded and welded. I though about modifying them, but I think I will buy these HD brackets from Pirate Camp Co. instead instead. As long as they fit, waiting on dimensions. A lot less work.
Anyone interested in very heavy stainless brackets? RM-005a.jpgbrackets.jpgScreenshot_20240423_120601_Chrome.jpg
TheDocAUS
12:50 AM
Eromanga
Anyone interested in very heavy stainless brackets? View attachment 7855543View attachment 7855544View attachment 7855541
If the Pirate Camp Co brackets do not work, KAON has a similar bracket that might.
AlanJ
Production/Transit
12:50 AM
Sydney
A few questions:
1. Yes it rotates by design, I actually find it handy. I can tilt the awing up slightly if needed to clean the rain gutter area.
2. Yes it does. Awning has been on the car since my initial post and zero signs of damage or the gutter bending down.
Reactions: GGR
